Air Cleaner inlet
Old Mar 7, 2006 | 09:36 PM
cootertwo's Avatar
cootertwo
Default Air Cleaner inlet
Hi All! I just pulled the air cleaner assembly from my 06 883, and removed the plug that conceals the "slow" needle. While I had the cleaner off, I noticed that there is an insert that has 883 stamped on it. It will pop out of the opening, providing a larger inlet for air!
I also was able to remove the carb needle plug without removing the carb, by using my dremel tool, that has a flex shaft, and drill chuck on the end. With the cleaner assembly out of the way, you can carefully drill a small hole in the plug. Screw in a sheet metal screw, and pop that baby out. My engine was sooooo lean, that with only 160 miles, it has already turned the pipes blue. And I had the occasional poot out the carb, when taking off. I backed the needle out 1/2 turn, and all is well! Cheap fix.[8D]
Old Mar 7, 2006 | 09:46 PM
Shift_4lo's Avatar
Shift_4lo
Default RE: Air Cleaner inlet
Rednex enginering at it's best. keep up the good work.
Old Mar 7, 2006 | 11:08 PM
alexcue's Avatar
alexcue
ORIGINAL: Shift_4lo
Ohh that's funny, i guess that's one way of looking at it!
OP: I wish i had seen what the orignal A/C looked like, but mine was switched out when i got it.
cajun1957a
Jan 8, 2019 04:26 PM
Aaronstottle
Sep 11, 2012 10:41 PM
ironman_sg
Mar 6, 2010 10:27 AM
2of2
Exhaust System Topics
Apr 28, 2008 10:28 PM
Beeracuda
Dec 29, 2005 07:52 PM
