I tried to post this when the board was totaled and kept getting kicked off. I work on tires for a living and have probably read all the pros and cona about nitrogen. The way I read it seems to only help in very high heat situations or if a tire sits for extended times the molecules are larger so they dont seep out the sidewall as fast. So unless you dont ride your bike or if you race it I think the best solution is to buy a good air gauge and USE IT
