Nitrogen in tires
Old Sep 21, 2012 | 10:39 AM
kneichko's Avatar
kneichko
Default Nitrogen in tires
How many guys are using nitrogen in their tires? Is it worth it or another gimmick?
Old Sep 21, 2012 | 10:41 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I use 79% nitrogen in mine, feels about right...
Old Sep 21, 2012 | 11:06 AM
slammed05fatty's Avatar
slammed05fatty
i run in my bike and it does seem to stay constant, very rarely do i have to add air, and my triumph sitting next to it has air and i have to add it about every month or so. so i am a believer of it
Old Sep 21, 2012 | 11:31 AM
cochon's Avatar
cochon
I run a mix in mine---78% nitrogen 21% oxygen and a slight mix of other gases. Only have to check the pressure if some of the oxygen leaks out.
Old Sep 21, 2012 | 11:32 AM
dbinbc's Avatar
dbinbc
Like the GrandPoobau said, we are all running 79% nitrogen in our tires, thats the percentage in normal air and it stays constant at that when pumped up to tire pressure. Definitely a gimmick.
Old Sep 21, 2012 | 11:33 AM
mkguitar's Avatar
mkguitar
Nitrogen does not expand/ contract as much as "air" this may be an issue is you regularly change altitude or if there are wide temperature swings where you are.
The larger nitrogen molecules are also less likely to leak out through rubber, so top ups are less likely to be required.
but for my $ I just use "air", I recognize the superiority of nitrogen filled tires, but the costs ( $8 or so around here) do not make sense for me.
Mike
Old Sep 21, 2012 | 11:40 AM
kneichko's Avatar
kneichko
thanks everyone. the dealer mentioned it to me and wasnt 100% sure if it was beneficial. i will stick with just checking my pressure and filling when necessary.
Old Sep 21, 2012 | 11:58 AM
Expat1's Avatar
Expat1
From: Annemasse (border of Geneva-Switzerland) facing Mt-Blanc.
Nitrogen pressure-temperature relation is predictable, moist compressed air is not. Certain applications such as aircraft landing gear tires are said to require nitrogen.
Old Sep 21, 2012 | 11:59 AM
TheGrandPoohBah
There was a discussion about this in a recent HOG magazine, and they said the MoCo is not taking a position on this at this time.
No mention of affecting the warranty...
Seriously, would probably be benificial to those dealing with wide temp ranges. The TPMS on my vehicles can easily vary 4-5 lbs. from temp changes from 80 to 55 degrees on cold tires at start up. To each their own...
Old Sep 21, 2012 | 12:08 PM
WestTexasRanger's Avatar
WestTexasRanger
Per my good friend and manager at Discount Tire Co.:
Nitrogen = Extra Profit
They don't offer nitrogen. They leave that up to the Car & Motorcycle Dealers to fleece the general public.
The local Ford Dealer gets $39.95
The Lexus Dealer gets $59.95
Nitrogen has it's place, but is a gimmick/waste of money on passenger cars, trucks and motorcycles.
