Lowering Front Fender
Old Aug 10, 2008 | 09:01 PM
wellreddevil's Avatar
wellreddevil
Stage III
Question Lowering Front Fender
I just bought an 01 883 Hugger and would like to lower the front fender a bit. It looks a bit dirt bikey to me. It looks as if I could only get about a half inch closer to the tire redrilling new fender mount holes, because after that the contour of the attach arms changes. Do they make a bracket for that? How close to the tire can the fender safely be? I'm new at this.
Old Aug 10, 2008 | 09:05 PM
Bluesssman's Avatar
Bluesssman
Simple fabrication. The bikes I build, I keep the tire to fender clearance at .3125" which is about 5/16"
Old Aug 11, 2008 | 08:07 PM
hdxl1200r's Avatar
hdxl1200r
I lowered mine. I taped a plastic hose to the top of the tire. I forget the measurement. Then lowered the fender down on to it. Mark the wholes in the existing bracket. Drill them. Put the fender back on and it looks alot cooler.
Old Aug 12, 2008 | 12:03 PM
jag1886's Avatar
jag1886
I've don it before it's very simple just drill aset of holes above the existing holes and cut the bottom off the fender bracket after you are done.
Deuuuce
Jun 29, 2017 01:57 PM
Poisond 08 Fatbob
Sep 5, 2010 11:00 AM
cjm8806
Jan 21, 2010 07:21 PM
dav.elis
Nov 18, 2007 07:49 PM
Wolhar
Jun 8, 2007 09:03 PM
