Rubber Mount Conversion
Old Mar 19, 2006 | 01:28 PM
coreyphipps's Avatar
coreyphipps
2nd Gear
Default Rubber Mount Conversion
Does anyone know if it is possible to convert a 2002 sporty to rubber mount?
Old Mar 19, 2006 | 02:38 PM
ronn39's Avatar
ronn39
Default RE: Rubber Mount Conversion
They did more to it in 2004 than just rubber-mount the engine. Changed the frame as well.
I'll add this info to get you an idea of what happened in the 04-06 models with the rubber-mounted engines:
"Because the engine no longer serves as a structural member, the 2004-06 Sportster frame is much stronger to compensate -- over 100% stronger than the 2003 version, according to Harley engineers -- and 26 percent more rigid when compared to the 2003 counterpart with the engine mounted. The down side is that the larger, thicker-wall tubing plus the various links and junctions needed to isolate the engine add plenty of weight -- about 50 pounds."
Old Mar 20, 2006 | 12:41 AM
mikeisglidn's Avatar
mikeisglidn
completlly different engines and frames. sorry, if you want rubbermounts gonna have to buy new ride!
Old Mar 21, 2006 | 02:11 AM
coreyphipps
2nd Gear
Good info. Thanks to all.
ShadowforNow
Oct 7, 2018 04:45 AM
russell6hp
Mar 24, 2010 05:55 AM
Dyna-Asa
Jun 14, 2009 12:42 PM
TowJam
VRSC Models
Oct 17, 2007 04:17 PM
grmf
Oct 7, 2007 05:15 PM
