Pull back bars
Old Mar 25, 2006 | 10:33 AM
jpw's Avatar
jpw
Stage III
Default RE: Pull back bars
Heather,
Thanks for the info. Can you tell me which "pull back bars" you used and how much of a problem it was to install.
Old Mar 25, 2006 | 03:30 PM
HeatherC's Avatar
HeatherC
ORIGINAL: jpw
Heather,
Sean installed them. They were the HD Sporster Pull Back bars. Sean will explain installation.
Old Mar 25, 2006 | 03:42 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
They are pretty easy to install.........depending on your wrenching ablity, I would say I am at a middle level of wrenching, with manual Four bolts on the neck, couple of bolts per switch housing and clamps. I would say get a service manual to assist with the connect of the new throttle cables, bleeding the new brake line and reconnecting the new clutch cable, if you have not done it before, best $50 bucks you can spend, safe alot of $$ due to HD's labor costs.
It took me a few hours, bleeding the brakes and adjusting the throttle cables took the most time for me
Old Mar 25, 2006 | 08:28 PM
jpw's Avatar
jpw
Stage III
I have an 02 Custom and would like to install the pull back bars. Can anyone tell me which bars I could use that would not require new cables. Thanks,
Jim
fxlr_93
Jun 14, 2015 07:38 PM
sawtooth_troy
Apr 1, 2015 03:49 PM
Wghussey
Aug 12, 2014 06:23 AM
DavidD
Jun 25, 2008 08:16 AM
ripper43
Mar 2, 2008 12:19 AM
