Sporty Down, Fluid Lost
Old Aug 27, 2008 | 08:16 PM
BoomerZoomer's Avatar
BoomerZoomer
Default Sporty Down, Fluid Lost
It happened. Lost control during a low speed maneuver and the bike ended up on the ground -- left side down. I was able to break it's fall and the engine guard saved the day.
But after picking it up, I noticed that fluid had leaked from the primary, and left a spot about 6" in diameter on the asphalt. I figure a couple of ounces were lost. I'm due for a primary/trans fluid change in about 2,000 miles. Can I wait till then? Or should I do it now?
Old Aug 27, 2008 | 08:23 PM
Dorkman's Avatar
Dorkman
Just add a couple of ounces through the inspection cover if you are concerned about it...I would.
Old Aug 28, 2008 | 07:12 AM
WVHogRider's Avatar
WVHogRider
+1 and check your gaskets & screw o-rings when you do it. It should not have leaked if it was properly sealed.
Old Aug 28, 2008 | 08:44 AM
BoomerZoomer
Thx. Last to touch the primary was the dealer.
Gonna' do it myself this time.
rsscoggins
EVO
11
Jun 21, 2019 10:54 PM
coylizard
EVO
13
Sep 21, 2018 07:47 PM
joebedford
Aug 2, 2015 06:39 PM
mike33ca
May 26, 2010 01:26 PM
clayharley
Apr 7, 2010 10:00 AM
