front brake problem...
Old Sep 10, 2008 | 12:25 PM
blackedout08's Avatar
blackedout08
Default front brake problem...
Can anyone tell me the correct wat to bleed the front brake ? I loosened the banjo fitting to try to give my line a little more play and when I squeezed the brake it was real soft ,I think I got air in the line and i want to bleed it.
Old Sep 10, 2008 | 12:46 PM
09sporty's Avatar
09sporty
at the brake on the wheel there is a bleeder valve/screw. Make sure your brake fluid reservoir is full, pump the brake handle until it starts to build pressure (maybe a dozen times), hold the brake lever in, crack the bleeder valve. At this point brake fluid should shoot out of the valve, or spurt/sputter, quickly close the valve. All this time you are holding the brake lever down, do not let up on it until you close the valve.
repeat until firm, and brake fluid shoots out in a steady stream (no sputtering).
Old Sep 10, 2008 | 12:48 PM
Spade115's Avatar
Spade115
I had to do the same to my rear brake line, I found out my rear brake is like new because it wasnt being used what so ever. So when we installed the new tire, and wondered why it wouldnt catch, we started laughing, close calls with no rear breaks.
SGMongoose
2014-2024 Touring Models
15
Nov 27, 2015 06:55 AM
zgunnar48
Apr 30, 2015 07:08 PM
logan hd
14
Jul 20, 2010 11:06 AM
thumperhumper
Wheels/Tires
Apr 19, 2009 05:32 AM
AirCommando
Jul 23, 2008 04:59 PM
