1998 Sportster 1200 custom dies when warm
Old Mar 26, 2006 | 09:05 PM
weaselphd's Avatar
weaselphd
Stage II
Default 1998 Sportster 1200 custom dies when warm
I have a 1998 Sportster 1200 Custom, and after several visits to the dealer they have still not fixed my bike, so i guess ill save my money and attempt to track tis down and fix it myself sincne the dealer here sucks..
can anyone give me some pointers, the nbike runs fine until it warms up say after 15 20 miles or so, then the bike DIES... it will not restart, until the bike cools down. But then it fires right up, a Honda i have had a similar problem but the regulator/rectifier was going bad, and those kill the battery so im stumped!
Any suggestions?
Thanks
Michael
Old Mar 26, 2006 | 09:27 PM
cmorris48's Avatar
cmorris48
Default RE: 1998 Sportster 1200 custom dies when warm
Son's 99 Sporty was doing the same thing, would shut down when warmed up. Engine would turn over but not fire. We replaced coil and problem went away....just a suggestion and not that expensive. Good luck
Old Mar 26, 2006 | 09:33 PM
weaselphd's Avatar
weaselphd
Stage II
Great thanks for the response i will look into that part and replace it see what happens...
thanks
Michael
Old Mar 28, 2006 | 02:40 AM
mikeisglidn's Avatar
mikeisglidn
three things usually make a sporty die first culprit is the coil, if not that ignition module, and sometimes the ignition switch is known to leave you behind, although the switch normally doesnt bite the dust just when it gets warm. good luck let us know what you find out
BD INC.
Oct 2, 2022 05:34 PM
MetalHead59
Mar 18, 2019 11:04 PM
Jimmy Coulston
Jan 30, 2017 07:10 PM
jonvincent834
Aug 3, 2015 03:08 PM
jcv400ex
Aug 24, 2006 01:33 PM
