I checked the archives, but not much there. I am changing to mini apes Friday, and want to get rid of the stock riser. Any good ideas on how to keep the stock instruments? Any kind of riser adapter??
If you loose the riser. the guages will hit the tank, unless you get the guages from any other sportster, they mount on the front of the risers, not the rear like the custom does.
I'll take some close up pics tomorrow in the sunlight, I used half of the old coil mount (coil is relocated to where the horn was) and mounted that bracket that I got from Summit.
