Alternative choke control?
just pull the choke out, start the bike, push the choke in, use the star screw on the throttle to hold a 1500 rpm idle for at least 30 seconds to a minute, than ride away, but go easy on the throttle for a mile or two, try to gun it hard and it will cough, but nothing major.
this is the actual process to start the bike, which is why im confused about why your trying to pull the choke and in and and in and out while holding the clutch in and trying to ride and trying to use your other hand, just doesnt make sense.
do you fill up your tank while sitting on the bike as well?
Outside Air Temp lower than 60 degrees F:
Enrichener fully out
15-30 second warmup at standstill
Ride for 3 minutes or 2 miles
Push enrichener halfway in
Ride for 2 minutes or 2 miles
**** in and you're off (as the old saying goes)
Outside Air Temp warmer than 60 degrees F:
Ride for 1 minute or 1/2 mile
**** in and you're off (as the old saying still goes)
Seems to pretty much do the job.
And I swear, if you have the tension screw set just right, you don't even need to touch the choke as it will slide back in on it's own as you ride off.
Oh, and show me some evidence that using your method keeps the plugs cleaner.
I think BW is trying to slow the idle before shifting into 1st to try to avoid the grinding of gently going into 1st from neutral. I think the best is to give the shifter a solid spank and not worry about it.
Just pointing out the facts.
i dont see the advantages of riding around on a really rich fuel mixture except to get the motor firing for the first few seconds. then just keep a high idle with the regular mixture to warm it up.
if you can defend why anyone needs to have the choke out at all except just to get it started then i will have to accept that. but there is no reason why you should flood your motor, which is trying to WARM up, with excess COLD gas inside the cylinder, it slows the warm up process and can foul your plugs quicker.
1. Open shop/garage doors.
2. Put key in ignition and turn on.
3. Turn fuel valve to on/run position and pull enrichener **** out. (being politically correct here, they don't call it a choke)
4. Twist throttle 2 or 3 times and push starter switch.
5. Bikes starts.
6. Several seconds later I engage clutch, shift to first and ease the sporty, or dyna out of storage.
7. Put bike in neutral and slide the **** in until you hear the familiar "giddyup" ( think you will find it is half out.
8. Close shop/garage doors. Open gate. Sit on bike. Engage 1st gear and ease out driveway
9. Turn or whatever and ride, if it is open road with no lights or stop signs reach down when convienient and push the kob in. If not, wait a light or two and the do it.
10. Listen to the engine it will tell you what it needs.
Sorry but this really is a no brainer and if I have po someone, sorry, but geez guys.
Hell, I even pointed out that I disagree with cHarley using a variation of throttle lock & choke, but that it was a matter of different strokes for different folks.
I also pointed out that you do not even need to touch the choke again after start up if you have a properly set tension nut on the choke & that the choke **** will slide back in on it's own as the engine warms.
Using the throttle lock to warm up the bike is increasing the engine rpm before the oil is pumping & warm enough to really flow efficiently, which I feel is worse on the rings & heads than burning up a plug, (which has never happened in the 8 years with this bike). I've only switched plugs one time & that was during my 1200 conversion. I'll just agree to disagree.....
