Sputter help
Old Nov 11, 2008 | 10:00 AM
MACSTAR100's Avatar
MACSTAR100
6th Gear
Default Sputter help
Hi yall, I'm new to the forum! It looks cool! I've got a 2001 XL1200c with 3650 miles on it. I have D&D slip on pipes and stock carb and intake. I recently have been getting a sputter out of first gear. It seems to miss when idling and doesnt seem strong and responsive like before. When its idling and I roll the throttle in neutral it seems slow not responsive. I believe it is starved for air. I took the air filter off completely just to test it and that seemed to remove the sputter. My question is instead of having it rejetted and go to a high flow cleaner, would it be worth my money to attempt a K & N filter first before doing that?? I'm trying to cut down on the cost of rejetting and high flowing it. Is there anything else I can do that would help, but not be harmful to the bike. Any suggestions??
Old Nov 11, 2008 | 10:26 AM
WRAITH's Avatar
WRAITH
Check your filter, hold it up to a light source. Light should easily be seen though it. If it is dark in color, it could be clogged with dust. Check your spark plugs. What color are they? A dark color, brown or black, would indicate too much fuel or a lack of air. White is a lack of fuel (lean) and mite require re jetting. Start with the simple things, before the expensive.
Old Nov 11, 2008 | 10:33 AM
MACSTAR100's Avatar
MACSTAR100
6th Gear
Wraith, thanks for your reply. The stock air filter is new. I also replaced the plugs and wires. The color of the plugs were dark brown so that would support the starved for air theory. I know the K&N filter would add a litte more air to it but I dont know if it will be enough.
Old Nov 11, 2008 | 10:39 AM
anubisss's Avatar
anubisss
A k and n IS a high flow filter. I would suggest putting one in. You can get them at Autozone for a reasonable price. The4n if you still ahve a sputter you could try adjusting the fuel/air mixture screw.
Old Nov 11, 2008 | 06:31 PM
robzuc97's Avatar
robzuc97
Dyno tune the bike and it will save you time and hassle. A good tune will set the correct jets and mixture plus get the most bang for the buck!
leenanj
Aug 19, 2016 05:26 PM
Rapter-10
Mar 12, 2013 10:47 PM
surf256
Apr 20, 2010 08:18 PM
BadNight09
Mar 21, 2009 11:49 AM
rj164
Jun 24, 2006 03:02 PM
