lowering kit
Old Feb 11, 2009 | 05:17 PM
Chop05c's Avatar
Chop05c
Default lowering kit
Has anyone used one of these "lowering kits" I see on e-bay? Most importantly, used with a side plate mount, it seems like it moves the plate mount back too far.
Old Feb 11, 2009 | 08:55 PM
Biptastic's Avatar
Biptastic
Do you mean the lowering bracket? If so id def get them. I have an inch lowering bracket on mine looks great(you dont even know there there) an doesnt effect the ride at all!! i think i paid $20 shipped for mine
Old Feb 12, 2009 | 07:29 AM
capttawes's Avatar
capttawes
Sure, go for it. If you're mounting your plate to the shock bolt I doubt it matters how far back it is. I run min on the axle (more stable, less vibes) and lowering brackets would definitely interfere with it.
Old Feb 12, 2009 | 07:33 AM
Chop05c's Avatar
Chop05c
Mine is on the axle also. By looking at them mounted I figured it would push the plate back too far.
Old Feb 12, 2009 | 07:41 AM
capttawes's Avatar
capttawes
With an axle mount and the lowering bracket I would think that if the plate mount worked at all it would be completely vertical with no lay back at all and look bad in my opinion.
Old Feb 12, 2009 | 07:50 AM
Chop05c's Avatar
Chop05c
I initially mounted it on the shock bolt but it was up just a bit too high, the tailight almost blended with the signal. I suppose I could put it back on there once it's lowered. Have to give it some thought.
luckypossum
Jul 8, 2014 11:20 PM
Road Star
Feb 26, 2014 04:28 AM
99ls1
Feb 13, 2013 05:04 PM
hdgzr
Feb 27, 2010 04:10 PM
tjl6722
May 9, 2006 11:55 PM
