My '08 1200C has been sitting in an outdoor garage all winter with no fuel stabilizer, no winterization, nuthin (except possibly a battery tender, but I'm not sure). It's been at a friend's house in Pa. and I had been planning to ride but never had the chance because of work.
Anyway, this is my first winter-to-spring transition ... can I just break her out and ride? Do I need to change the oil immediately? Any other suggestions (assuming the battery is not dead)? It got down to the single digits around here a few times this winter.
crank her up and ride man. if it don't turn just jump it or throw it on the charger for a few. make sure to check the tire pressure too. i would suggest an oil change but its not really a requirement.
Sounds like a plan. Is that brawler or the reach solo seat?
I have never winterized my bike.I don't see the point in it.I ride it at least once a month during the winter.I have however let it sit for over a month before,and it starts right up.Never put a tender on it either.19,000 miles, 6 winters, no gas stabilizer,and still the same original battery.
3 winters here with 30,000 miles and never used a stabalizer. I just keep the tank full and ride it when I can. If I know it will be a month or so before I can ride again I do plug in the tender.
The do nothing approach will allow condensation to build in your bike that will oxidize some internal engine components if your bike sits in an area with times of high humidity, such as a damp garage or outside. I've seen this begin to develop after two weeks of non-use in small airplanes, where the engines are similar. There's a few things you should do that really don't require any significant effort...
- Use a synthetic oil - it will protect inactive engine parts better for a longer period of time
- Put Sea Foam in the oil and gas per instructions when you stop riding for winter. This will help suspend any moisture that enters
- Use a battery tender
Change the oil at the beginning of the season. Make sure you run it first to operating temp to suspend any accumulated junk into the oil so you can get the crap out...
How long has it been setting? The problem with gasoline, other then condensation, is that it can form a gel like compound during storage. You might not be able to see these particles but your fuel injectors might. Don't know how long it takes to form but I know from car forums that if the gas is older then 3-4 months and hasn't been treated then they strongly suggest draining the gas. Cleaning or changing fuel injectors is expensive compared to the effort it takes to drain the gas.
Seaform was mentioned before you put away for the winter. If the bike will start, I'd immediately put some Seafoam in the tank now. That will help keep the injectors clean. Personally, I'd probably drain the gas. Put in fresh gas, AND Seaform.
