laydown plate mount question
Old Mar 17, 2009 | 08:05 PM
the kid01's Avatar
the kid01
6th Gear
Default laydown plate mount question
do you have to remove the tire to install a laydown plate mount . thanks
Old Mar 17, 2009 | 08:08 PM
deadhead111469's Avatar
deadhead111469
I didn't...just jacked up the rear a litle and stuck my arm up in the fender with a box end wrench.
Old Mar 17, 2009 | 08:29 PM
scotty-j's Avatar
scotty-j
i just squeezed my hand up there...one thing i did do is stop at the hardware store and picked up some stainless washers and nylok nuts, and longer allen bolts, the ones in the kit were too short to use the nylok nuts.
Old Mar 18, 2009 | 02:50 PM
stewy1200c's Avatar
stewy1200c
Nope, I didn't just snuck my hand in between tire and fender... tight fit but can be done.
Old Mar 18, 2009 | 02:52 PM
PAsportster's Avatar
PAsportster
Easy job , no jacking the bike up , like others said just put your arm in there , snug fit...I just put mine on..
Old Mar 18, 2009 | 05:03 PM
the kid01's Avatar
the kid01
6th Gear
i looked at the drag specialties one it seemed heavy or are they all built like that. thanks
Old Mar 18, 2009 | 06:34 PM
HOTLAP's Avatar
HOTLAP
Unless it's the fancy frame you want just remove yours, take out the support bracket, bend the mounting tab down and reinstall, presto...a lay down plate at no cost.
Old Mar 18, 2009 | 07:34 PM
deadhead111469
if you'll notice in my sig, my bike is lowered so it had to be jacked up a bit. also my arm is a little on the large side.
Old Mar 18, 2009 | 08:14 PM
WarriorHD's Avatar
WarriorHD
Yep...I also stuck my hand up there...tight fit...that's for sure....I couldn't see Shaquille O'Neal getting his hand up there...hehehe
Old Mar 18, 2009 | 09:49 PM
gilmour68's Avatar
gilmour68
I just bent the stock plate mount myself. I was able to reach up between the fender and the tire pretty easily...
Attached Thumbnails laydown plate mount question-2004-homemade-laydown-plate.jpg
