Air Shock Question
Old Mar 24, 2009 | 11:51 AM
jamesdeanblvd's Avatar
jamesdeanblvd
Default Air Shock Question
Ok, UPS just delivered my Road King air shocks. I know that some of you who have done this has mentioned using a spacer. What did you use for a spacer? How many will I need? Do they go on the top and bottom, or, just one end? Thanks, Chuck
Old Mar 24, 2009 | 03:47 PM
FastHoss's Avatar
FastHoss
Just use some thick washers,top and bottom,just enough to clear things on the side,do left and right the same,remember to check belt adjustment when you are done
Old Mar 24, 2009 | 08:01 PM
jamesdeanblvd
Thanks Doc. I was going to check with the hardware store and see if I can find some thick, small outside diameter flat washers that way I don't a bunch of skinny flat washers showing. Mine just came with plugs in the air shock. What is the best way to put valves in? Fill each shock at one time, or, make the kit so that they are both filled simultaneously? Thanks again, Chuck
Old Mar 24, 2009 | 08:07 PM
bmxatv's Avatar
bmxatv
post some pics when you get them on there!
Old Mar 24, 2009 | 08:51 PM
jamesdeanblvd
Anybody happen to know what size the bolts are in the shocks? I know, buy a manual. Anyway, any help would be appreciated.
Old Mar 24, 2009 | 08:57 PM
6o66er's Avatar
6o66er
I BELIEVE they are 5/8....I hate being at work and away from where I can check....I think they're 5/8. If you're talking about mounting bolts that is.
Old Mar 24, 2009 | 09:27 PM
jamesdeanblvd
Thanks for the info..
Old Mar 24, 2009 | 10:21 PM
Certainteed's Avatar
Certainteed
something to think about: balancing the pressure in both shocks is a pain. the dealer carries a kit that includes hoses etc. i think its $30
Old Mar 25, 2009 | 06:18 PM
jamesdeanblvd
I just took both the shocks out of their box and they look brand spankin new.. There is still the paint markings inside the mounting holes. Not one flaw. How Lucky.. They are part # 54565-97c. I just found a piece of paper left in from dealer and it said only 2 miles on shocks, 370$.. Good thing the guy at the HD store didn't see that note. 85 bucks including shipping.
Mborras1
Feb 21, 2019 02:21 PM
JDavis187
Feb 12, 2016 07:11 PM
jeemann99
Apr 4, 2015 11:40 PM
goldiedg
Mar 25, 2015 02:50 PM
bigtop1
Aug 14, 2008 08:16 PM
