Dont think its the ignition
Old Apr 13, 2005 | 01:02 PM
Ragin_Republican's Avatar
Ragin_Republican
Default Dont think its the ignition
Had problems starting the bike this morning again. Hit the start button and you can here the starter click, but not turn the motor over. After several tries it final kicks in. Could this be a bad starter? Bendix or solonoid maybe? How hard is it to replace the starter on an 883 evo?
Old Apr 13, 2005 | 01:35 PM
oldgeezer's Avatar
oldgeezer
Default RE: Dont think its the ignition
Sounds more like a battery. But, I qualify that statement by saying I'm not a motorhead.
Old Apr 13, 2005 | 02:42 PM
AceArt's Avatar
AceArt
Don't work on stuf much anymore, but years ago, if it was a car, I would agree with you and try the solenoid. Now that I'm older and lazier, I'll agree with OldGeezerand suggest you buy a "battery tender" and keep it on overnight and see if that cures the problem. The reason I suggest that is that you're prob' gonna want, need one at some time in the future and it's a pretty easy way to either pinpoint or eliminate the battery. BTW, What have the morning temps been?
It really doesn't sound like a battery to em, UNLESS, it's a batery connection. You might want to check and clean the posts/terminals. Again, I'm thinking the cheapest easiest fixes first and one's you're prob. gonna want to get around to sooner or later no matter what.
Hope you get it fixed quick, easy and cheap. Let us know what happens.
Hate tto ask this, but have you checked the fuel petcock? Aren't running home on reserve again, are you???
Old Apr 13, 2005 | 03:26 PM
Ragin_Republican
LOL. Actually, that was the first thing I checked. No offense taken. Got plenty of gas. It fired up fine for me at lunch time. First try. Not much warmer than it was when i came to work. Around 49 degrees. I have a battery charger but I'll check into a tender. I suspect the solonoid but I'll check the cheaper stuff first. Thanks for the help as always.
Old Apr 13, 2005 | 04:59 PM
oldgeezer's Avatar
oldgeezer
My Sportster acted the same way and it turned out being a battery. It would fire right up sometimes then occasionally act up. Without seeing or hearing it, it's hard for me to say though. Good luck. Pat
Old Apr 13, 2005 | 07:09 PM
mikeisglidn's Avatar
mikeisglidn
check the battery the positive post is probally loose, just happened to me yesterday!!
Old Apr 13, 2005 | 11:07 PM
SKJOLD's Avatar
SKJOLD
Loose ground will do that too.
Old Apr 14, 2005 | 12:53 AM
Ragin_Republican
Ok, I'll check out the connections as well. Thanks for all the help guys!
tbone44
General Topics/Tech Tips
13
Apr 3, 2015 08:39 AM
Eddy G
Mar 29, 2014 06:03 PM
martinez_nc
Feb 23, 2013 02:35 PM
kbob2000
Aug 18, 2012 04:11 PM
'75 Chop
Ironhead
23
Mar 2, 2009 05:28 AM
