Blinker fluid, what do you prefer?
Old Apr 14, 2009 | 07:19 AM
  #51
WVHogRider's Avatar
WVHogRider
I use Miracle Whip....Not that lame Helman's mayo stuff.
Old Apr 14, 2009 | 10:01 AM
  #52
JRK5892's Avatar
JRK5892
ha ha ha ha man it has been at least over a year since i have gone though a post and read every single response... i am sad to say you guys are all off... Every "REAL BIKER" knows... the only way to have your blinker fluid replaced the RIGHT WAY is to take it to the dealer! i mean come on... whats next you guys going to try and change your OWN grips or do your own oil changes here!
Old Apr 14, 2009 | 12:19 PM
  #53
Rider57's Avatar
Rider57
I ran out of blinker fluid 2 months ago but I do have some squelch grease for the CB. Can I use that instead?
Old Apr 14, 2009 | 08:30 PM
  #54
bbaz100's Avatar
bbaz100
Jiffy lube is running a special on the blinker fluid and jiffy stand lube. Their product allows the bulbs to run at 2X HD's recommended blink rate. You will need a rear bulb dyno adjustment. I believe the front bulbs are OK without it as they get better air cooling.
Old Apr 14, 2009 | 09:55 PM
  #55
RedlegRK's Avatar
RedlegRK
Yeah, but I hear they try and get by with using Chinese-made fallopian tubes. Only your certified ginuwine local dealer can give you the top quality American-made ones.
Old Apr 14, 2009 | 11:35 PM
  #56
sweetroll's Avatar
sweetroll
Originally Posted by soup7562
I've been using the dooflesnouzer midnight nightster black special blend. Cost me about $42.00 a quart. But I figure you only need alittle bit so I should be able to hold onto it for at least a couple o years. besides the parts guy at the stealer swore to me this was the latest and greatest.
My dealer has always told me to make sure and use blinker fluid from a sealed container for each maintenance interval. What alternate use is there for this fluid, since it only comes in quart size?
Thanks - I definitely want to get the most out of my money.
Old Apr 14, 2009 | 11:41 PM
  #57
midnight2005's Avatar
midnight2005
once you open the jug and pour some out, you have to throw it away. you never know what kind of impurities are in the air.
Old Apr 14, 2009 | 11:50 PM
  #58
sweetroll's Avatar
sweetroll
I'll make sure to dispose of it properly so some metric rider doesn't try and use it and blow his blinker's out...
Old Apr 15, 2009 | 03:57 AM
  #59
hollywood1959's Avatar
hollywood1959
If I had to guess, it's a good import vodka, wait till you see what it doe's for a ugly bitch at the bar! Keep it in the wind......................HOLLYWOOD
Old Apr 15, 2009 | 07:13 AM
  #60
Ramboamt's Avatar
Ramboamt
Originally Posted by vet767
Personally I like MGD Enough of them I don't really care what the "blinkers" do. I am just glad I am home and the scoot is tucked away in bed. Oh yeah. Prop wash works great on those hard to clean pipes. You know the ones. Where you got your boot a little close
For the times the prop wash just won't do the trick you need to use "Jet Blast". You also want to make sure that you rotate the air in your tires or it will drop the blink rate to an almost acceptable level.
