anybody ever just use taller risers to lift bars?
Old Apr 9, 2009 | 10:00 AM
iceman336's Avatar
iceman336
Default anybody ever just use taller risers to lift bars?
I have been wanting to get a set of taller bars for a while and have been leaning towards a set of mini apes or Z bars. It occurred to me today that perhaps a set of taller risers like the 6'1/2" or 8" with the factory style pullback (see below) coupled with my factory bars might work instead. Anybody ever do this and if so - pics of finished results?
Old Apr 9, 2009 | 11:04 AM
tiger_rider's Avatar
tiger_rider
I've used 4" pullbacks similar to those in your picture. They work well in pulling back the bars. I actually used the risers because the mini-apes I put on weren't long enough.
The problem that you will run into with these longer pullback risers is what they do the angle of the speedometer. On my wife's 1200L the pullback risers moved the speedometer so that its face was nearly vertical, its a very strange look.
Old Apr 9, 2009 | 11:55 AM
stng_96's Avatar
stng_96
Depending on how much you go, you may have to extend the cables too
Old Apr 9, 2009 | 12:59 PM
accrockett's Avatar
accrockett
I have HD drag bars with 6" risers on my Nightster. I LOVE the riding set up it gives me. I also have forward controls. Super comfortable.
Old Apr 9, 2009 | 01:34 PM
ghostflames's Avatar
ghostflames
Hey from Indy as well. Do you have any pics of that setup? I have been debating doing something similar but wasnt sure about the Speedo.
Old Apr 9, 2009 | 01:44 PM
accrockett's Avatar
accrockett
Ghostflames.....PM
Old Apr 9, 2009 | 02:32 PM
JRK5892's Avatar
JRK5892
i made my own riser ext's cost me 5 bucks and trip to local hardware store... lifted the sporty bars up!
did the same on the dyna
Old Apr 9, 2009 | 04:18 PM
Sail and Ride's Avatar
Sail and Ride
I put some spacers under the stock risers on my '05 Roadster, but still plan to use pull-back risers to mount a set of Dyna Low bars.
Old Apr 9, 2009 | 05:49 PM
dotcom2000's Avatar
dotcom2000
i had 8" risers and drag bars, but chaged it to 6" and bars off a new 883L. love the set-up. cables fit but wiring was about 2 in. short.
Old Apr 9, 2009 | 08:38 PM
zetaseven's Avatar
zetaseven
Put 41/2 up,,11/2 back on mine, then took 2 pieces of flat metal and bent them to make speedo and tach mount. Speedo was at bad angle.
