Horn problem
Old Apr 16, 2009 | 02:29 PM
kenward's Avatar
kenward
Default Horn problem
I just noticed that my horn is not working, thank god the finger is still functional,LOL. All the other electrical works fine lights, blinker speedo all function. Dont really know what to check at this point is anything else hooked in with it? is there a fuse?
Old Apr 16, 2009 | 04:34 PM
jeff.georgalas's Avatar
jeff.georgalas
I've had that happen both on my Fat Boy and on my S.G., but it's only ever happened after I got caught in a good rain storm. Typically it only does this for a day or two, and after it dries out (I'm guessing) it starts working again.
Old Apr 16, 2009 | 04:46 PM
capttawes's Avatar
capttawes
I think I've only used mine twice in 3 years and over 25k but water never seems to affect it. You might have a little corrosion on the contacts. You can also just take a couple wires and a 12v batt. and touch the contact posts with the batt. to see if it blows and if it does then the problem is in the switch.
Old Apr 16, 2009 | 10:35 PM
SportyPig's Avatar
SportyPig
My horn stopped working in mid beep. (just had the little disc horn between the forks). Turned out that the little clip on the horn where the electrical connects just broke.
Was a good thing. I replaced with a car horn. Don't sound like the little "roadrunner" anymore.
Old Apr 16, 2009 | 11:15 PM
tinman67's Avatar
tinman67
Default Get Louder Pipes
The stock beeper on Harleys are worthless. Mine works, but you can't hear it over my pipes anyway. I've been considering and air horn.
Old Apr 16, 2009 | 11:28 PM
m.breen's Avatar
m.breen
I bught a freeway blaster low tone for my sportster at Canadian Tire, around $40, its louder than stock. The last time my horn did not work, I shot some electrical contact cleaner into the switch and it fixed it, now I shhot electrical contact cleaner into all the switches at least once a year. I've known people to buy the low tone blaster for as little as $15 at Princess Auto. It fit behind the cowbell no problem.
Old Apr 17, 2009 | 01:07 AM
SteveCarney's Avatar
SteveCarney
I have never used my horn. Ever. It's not as loud as the pipes, and my hand' already on the throttle, so i usually just rev in place of a horn since the stock horn is crap.
Old Apr 17, 2009 | 08:03 AM
kenward's Avatar
kenward
I dont use a horn much either except on occasion when cruisen by a lil sweety on the sidewalk, however I would like to get it fixed to pass inspection. I also noticed The rear blinker lights dont stay lit up like the front, they will flash but dont stay on. I figure there must be some sort of electrical connection between the 2 issues but not sure what.
Old Apr 17, 2009 | 08:13 AM
deadhead111469's Avatar
deadhead111469
unless you have the run/stop/turn module on your bike the rear blinkers only work when turning...
dickey
Jul 20, 2019 11:53 AM
CGLTD
Apr 24, 2014 08:00 PM
BigDawgQC
Apr 19, 2013 02:51 PM
dan conner
Electrical/Lighting/Alarm
Mar 20, 2012 04:31 PM
SportyPig
May 17, 2008 05:22 PM
