help! back preasure question.
Old Apr 22, 2009 | 09:46 PM
xharleyx's Avatar
xharleyx
Default help! back pressure question.
ive had my nightster for 2 years. have vance and hines short shots of course. sound good but all my buddies took their baffles out and they sound incredible. so i decided to take the baffles out tonight. sounds incredible now, but my buddy followed me on the highway and said i was shooting blue flames every time i shifted.
i can't find good results by searching on here. does this mean I'm running rich or lean, and can this do any damage to my motor
and can it be fixed by a remap?
thanks for the help.
Old Apr 22, 2009 | 10:21 PM
motordrum's Avatar
motordrum
Do you not have a download or a fuelpak? That could be your problem. Or you could just get some marshmallows and make some smores!
Old Apr 22, 2009 | 10:34 PM
congo_usmc's Avatar
congo_usmc
i put these baffles in to replace the stock ones gives it a deeper tone than straight pipes, and maintains enough back pressure so there is no need for a remap or rejet. they are just as loud as without baffles. actually louder than all my buddies softails with straight pipes.
http://www.bigcitythunder.com/pages/...rmonsters.html
Old Apr 22, 2009 | 11:00 PM
pococj's Avatar
pococj
You started out running leaner than you were before removing the baffles. But from what I understand about the models with O2 sensors, the EFI system computer adjusted the mixture back to the stoichiometric ratio, as long as you haven't messed with the intake end of your motor. This also assumes you're running the sensors, and that the module is working as designed.
The short length of the pipes, coupled with no baffles to slow and disperse your exhaust gases, allow the flame to be seen. A mixture adjustment to richen the beast a bit would be good for your engine, and probably get you a wee bit more power, but the flames will still be there.
Old Apr 22, 2009 | 11:16 PM
xharleyx's Avatar
xharleyx
no fuel pack and no remap. how much does a remap at the stealer usually cost?
if it's a lot ill just get those big city thunders
Old Apr 23, 2009 | 01:46 AM
xharleyx's Avatar
xharleyx
you know what diameter those are right off hand?
Old Apr 23, 2009 | 02:26 AM
hollywood1959's Avatar
hollywood1959
Check out this web site. (harley-performance.com) It my tell you what you want to know. HOLLYWOOD
Old Apr 23, 2009 | 06:31 AM
guitarman023's Avatar
guitarman023
When it's really dark, even at idle you can see some flames just coming out of mine, when I crack into it hard and shift mine does that same thing. Mines got some mods though, and it's carbureted as well.
Old Apr 23, 2009 | 06:42 AM
congo_usmc's Avatar
congo_usmc
no, really cant remember but just call em up or email them. they got back to me the same day. they r a good company
Old Apr 23, 2009 | 11:09 PM
sweetroll's Avatar
sweetroll
The flames could either be caused by running too rich or too lean, depending on when they happen - do flames appear when you start to accelerate or decelerate? If it's accelerate, then it's running too lean when there is a quick twist of the throttle. If it's decelerate, then it would be running too rich right when you let off the throttle. There are portions of the ECM programing that deal with these specific areas, and compensate for them. Either way it's not very good for your bike, and may cause problems long term.
With EFI, tuning is the way to get around them, and if you have put a new intake on the bike then you should definitely look into a tuner. I have the fuel pak now (am getting ready to upgrade to a TTS tuner next month) and it helps. The PCIII or Dynojet seem to get good praise around here as well, but may require dyno time at the dealer, which is pretty expensive.
The fuel pak would be the cheapest way to go, and as long as all you've done is intake and exhaust, should help solve your problem. I won't be needing mine next month if you'd be interested in getting a deal on one...
John12676
Apr 24, 2014 07:53 PM
rlowride
Jan 23, 2010 11:24 PM
staygold13
Sep 18, 2008 09:00 PM
junk runner jr
Aug 14, 2007 03:57 PM
cajunman831
Oct 20, 2006 09:55 PM
