Popping
Old Apr 28, 2009 | 11:22 AM
BadNight09's Avatar
BadNight09
Default Popping
Just put on new pipes, new a/c, and installed a PCV from FuelMoto. As everyone knows, Jamie sends them out premapped. The bike runs great, I have way more power. The only problem is on decel it pops, quite a bit. I know everyone once in awhile is normal. But what about the majority of the time I lay off the throttle on high RPM's it gives a few pops? My guess was either call Jamie for a new map or take it in and get it dyno'ed. Any advice?
Old Apr 28, 2009 | 11:26 AM
stng_96's Avatar
stng_96
Yeah, its not running right, call and let her know what its doing, maybe she will be able to create a new program for you.
Old Apr 28, 2009 | 11:33 AM
Biker Trash's Avatar
Biker Trash
sounds a bit lean. a remap is in order
Old Apr 28, 2009 | 11:36 AM
BadNight09's Avatar
BadNight09
Is it going to jack up my engine in the short term? or is it more of a long term issue? or just ****ty gas mileage.
Old Apr 28, 2009 | 11:40 AM
Biker Trash
I'm more of a carb guy and not an expert on HD's fuel infection systems. on a carb the popping on decel is mainly an idle mixture adjustment.
Old Apr 28, 2009 | 11:46 AM
BadNight09's Avatar
BadNight09
I just talked to Jamie at fuelmoto, he said that the popping is because of the pipes I had, Hooker Darkside Troublemakers. His words were, because they are such a short pipe it is difficult to eliminate all the popping. He said no worries about engine damage, most popping is just the pipes and is just an annoyance more than anything. He gave me a quick fix on the map to try, and if it doesn't work he said to call back. Common problem with my pipes though.
Old Apr 28, 2009 | 12:06 PM
papadop88's Avatar
papadop88
Troublemakers, Short shots, etc will always have some popping...nature of the pipe.
Nothing to worry about.
Old Apr 28, 2009 | 12:14 PM
BadNight09's Avatar
BadNight09
That is a relief. Like I said, bike runs better than it did stock, just the popping. And of course that new pipes smell, it's going away quick though.
Old Apr 28, 2009 | 12:38 PM
whodatfan's Avatar
whodatfan
I have those exact pipes in question. She pops a bit. But I WILL tell you this. It was terrible with a can map pre downloaded in. I had mine dynoed and the fuel curve was WAAAYYYYYY off. It is much improved now and I picked up 3.5 almost 4 hp and 3.5 ft lbs torque. I'm at 77.5 hp max and 71.5 max torque. Way less decel pop too with the straightened out fuel curve.
Old Apr 28, 2009 | 12:53 PM
BadNight09's Avatar
BadNight09
Yeah, jamie is having me set the 0% column to 15%. I'm gonna see how much it helps out.
