I just picked up a 2001 Sportster 883 and I'm wondering what I could do to get a little more pick up speed. It's a great bike but I would like to beef it up a little bit. Any thoughts would be great. Thanks.
If ya go on the HD site, at the top of the main page there is a link for Harley experience, Follow that to racing link on the next page. I hadn't seen this while I had my sportster, looking back it was probably a good thing$$$$$
Go to this web site harley-performance.com It should answer a few questions for ya. Allot of good reads in there. Let us know................ HOLLYWOOD
The bike has Screaming Eagle exhaust but that's about it. How do air filters differ and how much difference would changing just the filter make? For example, if I got a Screaming Eagle air cleaner vs. a Big Sucker? They obviously sit differently on the bike. I would assume the Screaming Eagle or forward facing air cleaners would be best but I'm not sure. How difficult is it to upgrade my carburetor and change it out? I also assume that you don't want your bike running too rich or too lean but in the middle for maximum performane, correct? Last question right now I guess would be by changing the air filter and carburetor, how does that generally affect mileage?
You don't need to change out the carb. There's nothing wrong with the stock carb, and it can handle your engine say up to around 100 HP. Since you already have the SE slip-ons, you'll just need to re-jet the carb once you change the AC to a higher flowing one. Any open element AC will do, and you really will not notice a huge difference from one high flow AC to another....But you will notice the difference from the stock AC to the high flow AC. Just pick a style of AC that you like. Mileage will go down slightly with the high flow AC due to re-jetting to add more fuel due to increased air flow in, but not drastically....Although that also depends on how heavy you are on the throttle.
