Put the spring in a vise, bend it over and slip nickles in all the open spaces that you can get in. Put the spring on with the stand up. When put the stand down the nickles will fall out or be easily removed.
Also, did it pop off when you maybe hit something? If so, it is probably bent and you will likely need a new spring.
That's a neat little trick. Proof right there that someones always thinkin.
