Oil Change
Old May 7, 2009 | 06:59 AM
dsuppa's Avatar
dsuppa
Default Oil Change
So Im about to try my first attempt at servicing my bike myself, don't feel like spending so much on service at the dealer. Went to get the oil and this is what the person recommended I use.
In my Clymer manual it recommends HD oil...does it really matter? And has anyone used this oil before on their sportsters?
Thanks for the help
edit: the glare is covering a little, but it is SAE 20W/50.
Old May 7, 2009 | 07:11 AM
xFreebirdx's Avatar
xFreebirdx
It would be safer to search this forum.
Old May 7, 2009 | 07:19 AM
murphy08's Avatar
murphy08
nope cant say I have just change my sat use the H-D oil 20W/50
Old May 7, 2009 | 08:15 AM
dsuppa's Avatar
dsuppa
Maybe I should just return this stuff and get the HD oil from dealer, hell it cant be that much more that I paid for this oil at $5 per q
Old May 7, 2009 | 08:41 AM
old skool1983's Avatar
old skool1983
don't get the HD oil, no point and the oil IMO is cheaper quality.
the 20w50 is good stuff, just make sure its motorcycle oil, there is a difference i believe.
good for you doin yr own work
Old May 7, 2009 | 08:45 AM
JayStronghawk's Avatar
JayStronghawk
Used Amsoil 20W50 for everything on my 04 Sporty for 3 years with the Finest of results.. With 5 Blackstone Oil test results showing engine was in top shape..
Old May 7, 2009 | 09:31 AM
deadhead111469's Avatar
deadhead111469
I use the valvoline oil in mine with no problems.....but I use the motorcycle blend
Old May 7, 2009 | 09:32 AM
dsuppa's Avatar
dsuppa
I saw no "motorcycle blend" ones it was just the reg Valvoline or this VR1 Racing Oil.
Old May 7, 2009 | 09:36 AM
packer's Avatar
packer
Ditto That
Old May 7, 2009 | 09:52 AM
guitarman023's Avatar
guitarman023
if your top end doesn't make a lot of noise, then you should be fine. The only reason I run HD oil in mine is because it quiets down the sewing machine on board my bike. That's the only difference I've found with the HD oil.
