still clunking
Old May 8, 2009 | 12:27 PM
mbwannabe1's Avatar
mbwannabe1
Originally Posted by xFreebirdx
there is a min and a max mesurment. i don't know off the top of my head what the specs are. it is also a warm chain cold chain spec.
3/8" is the max for cold and the min for hot (at least for my '08). That part is okay. Turn the rear wheel to find the tightest spot. Then measure deflecton from the same spot on the chain -- from the farthest you can push it down to the farthest you can lift it up. If that is 3/8", it doesn't matter if it's hot or cold.
Adjusting a clutch is simple, and I'd do it anyway (adjust a clutch COLD, not hot), but I'd also be very suprised if that fixes your problem. Is your drive belt loose?
Old May 8, 2009 | 04:26 PM
schumacher's Avatar
schumacher
all 3 of mine clunked. I liked it, myself
Old May 9, 2009 | 12:27 AM
matinees's Avatar
matinees
do u push it all the way down and lift it all the way up from there for your measurement.If so i did it wrong i just measured from where it was to lifting it up
D W K
Jul 26, 2017 08:32 PM
Rickierockit92
13
May 24, 2016 07:34 AM
98glider
EVO
Oct 12, 2011 05:02 AM
steelerdude1
Aug 20, 2011 10:11 AM
JustDave71
11
Jun 12, 2010 11:08 AM
