Lost power while riding.....????
Old Jul 28, 2009 | 04:06 PM
FastHoss's Avatar
FastHoss
Put in a new system relay.Happened to me.Every 4,000 miles I loose a system relay,you will begin to notice stuff that happens when they are on there way out.
Old Jul 28, 2009 | 04:51 PM
Mattyboy's Avatar
Mattyboy
already though? i have only 2400 KMS on it
Old Jul 28, 2009 | 10:45 PM
BlockHead96's Avatar
BlockHead96
Do you have the turn signal, brake light, running light kit installed?
Old Jul 29, 2009 | 08:05 AM
Mattyboy's Avatar
Mattyboy
not sure. its stock except for stage 1
Old Aug 7, 2009 | 12:02 AM
E Smitty's Avatar
E Smitty
Have you found the reason for this yet? I have an 08 Nightster and it has been doing the same thing.
Thanks
E
Old Sep 7, 2014 | 11:41 PM
reidusu94's Avatar
reidusu94
Stage I
Hey I was wondering if you ever found out what was wrong with your bike. My 09 nightster is doing the same thing with turning off while driving.
Old May 1, 2018 | 10:25 PM
13HDSBFXDB's Avatar
13HDSBFXDB
Stage I
Default Same thing
I was on my way to work the other night and all of the sudden my oil light came on. The bike then lost power, I pulled in the clutch and hit the starter and it came back to life. After a few times of that the bikes check engine light came on and it totally lost power, when I turn on my turn signals they act up but not all of the time other than that it will run just fine. It sounds like a wiring problem but where would i start?
Old May 3, 2018 | 04:54 PM
BlockHead96
My 08 FXDL did this often then started blowing fuses. I've heard a lot about this happening on the bikes with the factory alarm! For the life of me I couldn't figure it out and the stealers could care less! They are of the mind if they don't acknowledge it, it doesn't exist, therefore, not the MoCo problem. Now then, I believe I stumbled on my problem and I believed I fixed it! I separated the two halves of the twist throttle housing on the handle bars, low and behold, a couple wires were pinched between the two halves... The problem never returned... Hope this could possibly help anyone.
Olsen185
Oct 26, 2015 06:36 PM
DanDman
Aug 8, 2015 08:33 AM
schoppa
May 2, 2012 07:28 PM
Comatose
EVO
Nov 26, 2011 07:36 AM
ratdogmiller
VRSC Models
Jun 10, 2008 01:04 AM
