Oil blowby from the dipstick??
Old Jul 27, 2009 | 08:09 PM
mxz600's Avatar
mxz600
Default Oil blowby from the dipstick??
Is this possible? I have oil coming out of the dipstick when I ride and making a mess of everything. Nothing is coming out the air filter. I changed the air filter about 900 miles ago after it was soaked in oil. The oil is about half way on the dipstick so do not think it is overfull. Any ideas?
Old Jul 27, 2009 | 08:19 PM
SpursDarkrider's Avatar
SpursDarkrider
dipstick? what year bike do you have?
Old Jul 27, 2009 | 08:36 PM
mxz600's Avatar
mxz600
It is a 2006 1200. Does this make a difference?
Old Jul 27, 2009 | 11:35 PM
bwana1's Avatar
bwana1
There is too much oil in the tank. If the oil is half way between the marks on the dipstick when the engine is cold, lower the oil to the 1/4 mark.
Bwana
Old Jul 28, 2009 | 06:57 AM
SportyPig's Avatar
SportyPig
Sounds like maybe the O-ring seal on the Dipstick is damaged.
Old Jul 28, 2009 | 07:09 AM
JayStronghawk's Avatar
JayStronghawk
Pray that your oil level is too high or the dipstick is not inserted properly only other reason would be crankcase pressure spitting back when returning the oil which is bad news ..
Old Jul 28, 2009 | 07:34 AM
xFreebirdx's Avatar
xFreebirdx
+1 Jay is right on the money. The dipstick should fit tight and be seated all the way. Inspect the dipstick gasket for any damage from not putting it back on right. I hope thats the problem.
Old Jul 28, 2009 | 05:29 PM
Bentwrench's Avatar
Bentwrench
Default Blowing Oil out Dipstick
If you haven't found a damaged O-ring on the oil cap seal, then you might want to consider other possible causes.
One of the things that can happen with oil is that it can foam up. Oil is supposed to have anti-foam agents in it to prevent excessive frothing. If you have recently changed brands of oil, you may want to go back to what you were using prior to the last oil and filter change.
You might also want to check to be sure the oil tank vent line isn't plugged up or kinked.
Just a thought, FWIW.
arod6
Oct 4, 2015 02:27 PM
Coastiebob
Jun 20, 2012 08:40 AM
truthfire
Apr 4, 2011 02:04 PM
icedearth
Aug 8, 2007 03:06 PM
IronLegend
Apr 18, 2007 04:52 PM
