enrichener knob
Old Jul 28, 2009 | 08:47 PM
Steel's Avatar
Steel
Question enrichener ****
Hello
I have a 2001 1200C, when I pull the enrichener **** out and start the bike it sucks in right away. Whats happening? Anyone know?
Thanks
Wade
Old Jul 28, 2009 | 10:16 PM
Bentwrench's Avatar
Bentwrench
Default Enrichener Cable Friction
The friction of the enrichener cable is adjustable, at least it is on my '96.
Loosen the hex nut on back side of the **** bracket. Don't remove it, just loosen it. There is a black plastic ring on the **** side of the bracket. Tighten it slightly until you get the resistance you want. Then snug up the hex nut, but gently. Remember there is plastic involved.
Old Jul 28, 2009 | 10:22 PM
old skool1983's Avatar
old skool1983
+1 on this,
however, mine actually broke, the plastic threads broke off so adjustment was not possible. when i had to get into the carb i just pulled it off and replaced the choke cable, it was only like 12 bucks. not really worth pullin the carb for just that IMO but next time yr gonna pull it ya can fix it then, untill then....well i used a nickel that i cut in half, its the perfect size to get a steady idle
Old Jul 28, 2009 | 10:34 PM
notfried's Avatar
notfried
we used zip-ties on my neighbor's broken choke cable on his '97
Old Jul 29, 2009 | 07:34 AM
WVHogRider's Avatar
WVHogRider
There's no need to loosen the nut on the back side. Just slightly tighten the plastic ring on the **** side to the proper tension, and all will be good. That's how I adjust mine, and it sucks itself in as the bike warms up sitting still or riding down the road.
Old Jul 29, 2009 | 07:51 AM
XL50#674's Avatar
XL50#674
My step dad has an 02 883 and it sucks the **** in about half way once it starts up and you have to pull it out. I'll now have to see if I can adjust it for him. Just one more reason I love FI.
Old Jul 29, 2009 | 07:52 AM
old skool1983
INSERT FART NOISE HERE!
Old Jul 29, 2009 | 08:10 AM
WVHogRider's Avatar
WVHogRider
Isn't that the truth. I'll take a carb over FI any day.
Old Jul 29, 2009 | 12:41 PM
Steel's Avatar
Steel
Hey thanks people!!!!!!!!!
Old Jul 29, 2009 | 12:51 PM
Sick1200's Avatar
Sick1200
People would rather download something than turn a wrench.
