Leaking air?
Old Aug 27, 2009 | 08:44 PM
YmeHP's Avatar
YmeHP
Angry Leaking air?
I've got a spoked wheel that is leaking air through one of the spokes. What is the trick to getting this stopped? I've tried tightning and loosening up the spoke but have had no luck. i'm at a loss and it's annoying...thanks
Old Aug 27, 2009 | 09:14 PM
Gpsjr10's Avatar
Gpsjr10
Sounds like you need a new inner-tube. And the big rubber band guard that protects the tube from the ends of the spokes.... should inspect the spokes to find out what caused the puncture.
Old Aug 27, 2009 | 10:03 PM
YmeHP's Avatar
YmeHP
Red face
thanks!
Old Aug 27, 2009 | 10:07 PM
WRAITH's Avatar
WRAITH
The inner tube has been punctured and needs to be replaced.
Old Aug 27, 2009 | 10:31 PM
UPSBROWN's Avatar
UPSBROWN
Make sure they put a new rubber band thing on the rim also. Sometimes they do it, sometimes they don't.
Old Aug 27, 2009 | 10:53 PM
YmeHP's Avatar
YmeHP
Thanks, I must of had it tied down to tight while being hauled.
Old Aug 28, 2009 | 12:35 AM
Certainteed's Avatar
Certainteed
dude if you were tightening / loosing spokes you need to have your wheel trued. unless you trued it. then you can ignore this message. otherwise, take the wheel to a shop and have it unfcked as soon as possible.
Old Aug 28, 2009 | 02:20 AM
fastkevin's Avatar
fastkevin
Nope.... A bike needs to be secured tightly. I've never heard of anyone cinching down a set of tie-downs to the point where they flatened a tire.
As others stated, your rim strip is what keeps the spokes from poking into your tube. Yours is either breached or it's shifted. You can even put a layer of duct tape in there as well as an extra layer.
Old Aug 28, 2009 | 06:31 AM
guitarman023's Avatar
guitarman023
+1 on duct tape, nothing like an insurance policy.
Old Aug 28, 2009 | 06:35 AM
midnight2005's Avatar
midnight2005
for some reason, I knew Duct tape was going to be in this flat tire thread somewhere.
Cristofrshon
Aug 16, 2016 07:50 PM
Aargow
Wheels/Tires
May 15, 2013 09:45 AM
trooper50
Apr 25, 2012 06:11 PM
Dynaryder85
Jan 15, 2012 04:23 PM
jm04
Jun 21, 2009 09:40 PM
