Need help with clutch adjustment PLEASE
Old Sep 2, 2009 | 07:58 PM
huffy33's Avatar
huffy33
Stage III
Default Need help with clutch adjustment PLEASE
Sorry guys,
Im new to all this and have run into an issue and really could use some help.
I just purchases a new windshield for my 05 883 XL. I was in the process of moving the clutch cable as stated in the set up. Seemed pretty simple following the directions. After tightening up the clutch cable with the adjuster bold and lock nut I seem that I cant get my clutch to engage. I have tried with the 1/16 gap as recommended, tighter, and looser with the same effect. Each time i have tried to start the bike it wants to take off. Do I need to find neutral and let it run for a while and build the fluids up? Did i accidently twist the cable or something? I just cant seem to figure out what in the world I have done wrong. I have now went through the set up probably 10 times with the same effect. Please help.
thank you
Old Sep 2, 2009 | 08:36 PM
gilmour68's Avatar
gilmour68
I could print and fax you the page(s) from the Clymer manual if you'd like. It's not that difficult, but a picture (or pictures) is worth a thousand words.
Old Sep 2, 2009 | 08:59 PM
huffy33's Avatar
huffy33
Stage III
that would be great anything to help. I have the owner manual and I have walked through all the steps time and time again. My big concern is that with the bike off and the clutch pulled I cant move it which is telling me the clutch is still engaged.
Old Sep 2, 2009 | 09:31 PM
F1J1's Avatar
F1J1
It's a bitch to do. There's a full bore explanation in this forum somewhere which "makes it simple." It's still a bitch....
Old Sep 2, 2009 | 09:50 PM
drum412's Avatar
drum412
what do you mean the bike wants to take off when you try to start? Are you trying to start while in gear??? Always start in neutral. Sometimes clutch drag from oil can be enough it can cause the bike to roll a bit if started in gear. So like I said, always start in nuetral, alot of the drag issue clears up once the clutch starts spinning fling oil out of it. But also go over your clutch adjustment once again, just to make sure you did everything properly.
Old Sep 2, 2009 | 11:14 PM
scotty-j's Avatar
scotty-j
here are two write ups for you, with pics too.
clutch adjustment
http://xlforum.net/vbportal/forums/s...ad.php?t=49376
primary chain adjustment discussion
http://xlforum.net/vbportal/forums/s...ad.php?t=10084
clutch install with adjustment info as well
http://xlforum.net/vbportal/forums/s...ad.php?t=49915
Old Sep 3, 2009 | 12:47 AM
huffy33's Avatar
huffy33
Stage III
Default Thank you
Thanks guys
Old Sep 3, 2009 | 05:40 AM
MechsHands's Avatar
MechsHands
I ran into a similar problem when installing my fwd controls. I thought i had messed something up. Put the gap the way it should be (like you said you have) start it in nuetral then try it. You shouldnt have any problems then. I spent hours thinking I had messed something up when I hadnt.
MH
Raiders067
Nov 2, 2017 07:38 AM
0204665J
Apr 14, 2013 08:39 AM
BuckeyeGuy525
Sep 26, 2011 01:57 PM
Darthvader
May 13, 2008 06:36 PM
jdtest
Jun 25, 2007 09:35 PM
