DTC code U1097
Old Sep 3, 2009 | 12:55 PM
HOTLAP's Avatar
HOTLAP
Default DTC code U1097
I got a DTC code U1097 "loss of speedometer serial data to ECM"
I have cleared it to see if it shows up again or was just a fluke but was wondering if anyone knows what that means.
Old Sep 3, 2009 | 01:08 PM
FastHoss's Avatar
FastHoss
I would be checking your fuse box for corrosion,also replace your system relay,my 07 would start this kind of crap right before the system relay would go south.
Old Sep 3, 2009 | 02:58 PM
cHarley's Avatar
cHarley
+1 - Also clean the ECM contacts and coat them and all electrical contacts with dielectric grease.
Old Sep 3, 2009 | 03:26 PM
HOTLAP's Avatar
HOTLAP
Thanks, I will get a system relay just in case and check the ECM connections, I added a PC5 about a month ago so maybe something has vibrated a bit loose there, maybe I should zip tie the connectors onto the ECM and the PC5,
I'm hoping it was a one time thing but I'd rather be prepared. I'll take it for a long ride after work and see if the code reapears.
EricD701
Electrical/Lighting/Alarm
Jan 6, 2018 10:59 AM
RussH
Sep 1, 2013 03:24 PM
klwsparks
Mar 4, 2012 07:41 AM
theindian
Jun 4, 2011 05:45 PM
cdem02
May 3, 2007 05:34 AM
