I ride it for a couple miles to let the engine warm up, then i check the level while on the sidestand. I unscrew the cap, wipe the stick clean then reinsert and twist but not lock and then take a reading.
Bike on the jiffy stand, motor Hot, and the dipstick fully installed.
cHarley I have learned to respect your opinions but I have to respectfully ask for a clarification on this one. As per my HD manual for the 2000 883 I have always placed a 2X6 under the jiffy stand to hold the bike vertical while checking the oil. Is there different instructions for a 1200? I have also been filling to a point about halfway between the two marks on the dipstick to help avoid the spaying of oil from the breather assy. Can you clarify please.
I'd say refer to your Owners Manual here. On the 04 & later Sporties, the manual calls to the oil level to be checked with the bike on the jiffy stand.
All in all, I don't think that tipped on the jiffy vs upright makes all that much difference if your like most HD owners that have learned that keeping the oil level about mid way between the ADD & FULL marks reduces oil blow-by into the air cleaner. Keeping in mind here that raising or lowering the (shocks) bike, affects the lean angle when on the jiffy stand. I'm running 12.5" rear shocks, so I put a piece of 1x8 under the jiffy to compensate.
Here is a way to make your life a lot easier when checking your oil. After a fresh change and you have verified that you have the correct amount of oil in your tank, after a complete warm up, let the bike sit until it has fully cooled down, or better yet, let it sit a day or two. The idea is to allow adequate time for all the oil to completely settle. With the bike resting on the jiffy stand, carefully pull the dip stick, note where the level is and simply scratch a horizontal mark on the stick at the point where the oil level is at. This makes it a simple process of checking the oil before every ride and you're not having to do a balancing act with the bike and a hot engine. You may have to be extra cautious if you are using a digital read out stick but for all practical purposes, this simple solution works quite well.
That works fine until you get a piece of trash in the oil system that causes the oil system check valve to not seat properly. If (when) that happens the oil in the tank will slowly drain down into the motor sump. If you refill the tank under these conditions you will overfill the system and then have a real headache.
The manual tells you to check the oil level HOT for a reason.
Good point cHarley! I'm sure my approach isn't for everybody but been using it for over 10 years now and never a problem. But I'm sure having my check valve stuck slightly open only once, as described in your scenario, and overfilling would change my opinion rather quickly : ) Discovering the oil level unusually low at any one time, at least for me, would make me suspicious of a potential problem. But again, this approach probably isn't for everyone.
