2007 Nightster oil leak from dip stick
Old Sep 19, 2009 | 09:45 PM
cvandi4402's Avatar
cvandi4402
Stage I
Default 2007 Nightster oil leak from dip stick
Just traded off my 2007 1200 Low for a 2007 Nightster. I've noticed on long rides oil leaking from the dip stick. The dip stick isn't the original. It's the stick with the temp gauge. Unfortunately I'm not mechanically inclined. Is this common with the oil gauge? Also, the bike has the screamin eagle heavy breather air cleaner and vance and hines shortshots-don't know if that's important to know.
Old Sep 19, 2009 | 09:49 PM
midnight2005's Avatar
midnight2005
no the exhaust and ac is not important in this case, but good thinking there. I would say the dipstick is probably not made for that bike, or it is defective. How much oil is in it? is it overfull? Find a stock dipstick is my suggestion. If you traded at a dealer, ask them if they would replace it with something that does not leak.
Old Sep 19, 2009 | 11:23 PM
old skool1983's Avatar
old skool1983
+1...this is everything i was gonna say.
one little thing, it might not be the dipstick that is faulty but possibley an o ring on the dipstick. thats the only other thing i have to add
Old Sep 20, 2009 | 07:01 AM
JerryZZ's Avatar
JerryZZ
6th Gear
I had the exact same problem with this dipstick. The oil was getting pushed inside the dipstick, filling the body with oil and then oozing out under the cap which is outside the outer o-ring spilling out the top of the tank. I did take it back to the dealer and got a replacement. As soon as I got the new one home, I disassembled it using a very small torx and I completely filled the inside of the body with silicone glue and then reassembled. It has been tignt as a drum ever since. Maybe I didn't need to do that, but the glue will never stick once the inside gets oiled up, so I did it as a precaution. I think it is a good mod to be sure it stays tight.
motocat13
Jul 7, 2012 09:10 PM
craneguy
Sep 22, 2010 11:46 PM
WARG
Dec 28, 2008 02:45 PM
Curlingace
Dec 29, 2007 11:28 AM
mmuth1
Jul 30, 2007 03:20 PM
