using oil
Old Oct 11, 2009 | 04:29 PM
JJW's Avatar
JJW
Stage II
Default using oil
New to forum and HD. Just bought a '05 1200C with 270 ml. on it.Previous owner got sick and didn't ride it so the neighbor would fire it up and ride it around the block for her. I've put 2k on it in the last 2 mo. First 1000 pretty conservatively. My ? is, it uses oil. Alot. Have to add 5 or 6 oz. every 200 miles. Is this normal, are rings seated yet. No leaks and no smoke. Any ideas? Thanks, Jeff
Old Oct 11, 2009 | 05:01 PM
hogsport's Avatar
hogsport
You did not indicate if you are trying to maintain the oil level to the "full" level or above the "fill" level. Assuming you are taking it to full, try maintaining the oil level 1/4 above the fill level and see if it maintains there. You may also be noticing some oil dripping from the AC?
Old Oct 11, 2009 | 06:21 PM
RATROD HOG's Avatar
RATROD HOG
keeper on the low side (oil) and see what happens,them motors are rugged
Old Oct 11, 2009 | 08:54 PM
cHarley's Avatar
cHarley
05 models have a known issue with a bad valve seals and the MoCo (was) replacing them under a Service Bulletin. I don't know whether they will still honor the "no cost" replacement after this long though.
A quick check for leaking valve seals is to, while on the jiffy stand and in neutral, give the throttle a hard rev and then quickly slam the throttle closed. As the motor winds down look for any wisps of smoke from the exhaust pipes. If you see any smoke the valve seals are leaking.
JoelA
Jun 27, 2013 10:02 AM
kirby
Jul 25, 2010 09:04 PM
Stellier
Aug 22, 2006 10:28 AM
Anthony8858
Oct 2, 2005 09:51 AM
sikorajm
Jun 27, 2005 05:55 PM
