Compression tests
Old Nov 2, 2009 | 07:47 PM
Certainteed's Avatar
Certainteed
Default Compression tests
The other day i'm cruising along and I feel a weird vibration when the engine is unloaded... or, when the throttle is feeding the exact amount of fuel required to maintain speed. I swear it feels like a bearing. I change the oil and everything looks as it always does. I'm a bit worried. So I do a compression test and nothings changed since the last compression test 20k miles ago. 185ish. This is when I decide to check the manual to see what it should be. Ugh, its supposed to be above 200psi. And whats more, it jumps to 240ish with a squirt of oil.
What a pain in the ***.
Old Nov 2, 2009 | 09:06 PM
OldFenderGuy's Avatar
OldFenderGuy
Did you run a compression check of both cylinders?
If so was the variance between cylinders more than 10%??
Old Nov 2, 2009 | 10:01 PM
Certainteed
Front cyl is lowest at 170 dry / 240 wet. Rear is 185 dry / 250 wet. I know this has nothing to do with vibration or bearings, but I got the ******* now so I'm in paranoid-test-mode.
Old Nov 2, 2009 | 10:14 PM
RATROD HOG's Avatar
RATROD HOG
this might be your answer? pfft. 08 w/ 42,000 miles.
__________________
Old Nov 2, 2009 | 11:06 PM
Certainteed
the warranty says nothing of mileage limits. i didn't buy it to be ***-jewelry, hotrod.
Old Nov 3, 2009 | 05:45 PM
Certainteed
well she's at the shop now. i told the tech about the vibration and the compression tests results... the look on his face spelled d o o m. but, they took the nightster in and cut the 1125r loose early (since i dont have a car). i guess i'll hear the results in a few days, but my guess is its going to need rings.
the silver lining is the 1125 got a new download and the herky-jerky fueling problems are gone. my last suspension changes were a welcome change. i zoomed around the backroads a bit today and had a great time. it keeps getting better and better.
Old Nov 3, 2009 | 08:16 PM
bmxatv's Avatar
bmxatv
__________________
he left himself wide open for that one.......nice.
Old Nov 3, 2009 | 08:41 PM
Certainteed
sounds like somebody is happy about my misfortune.
this leg welcomes no hump.
Old Nov 3, 2009 | 09:15 PM
old skool1983's Avatar
old skool1983
dam dude 42k and yr lookin at rings? that freakin sucks, seems like that milage is WAY to low for rings...keep us posted, sorry about the deal
Old Nov 4, 2009 | 09:15 AM
fox4's Avatar
fox4
Yeah I would say rings for sure especially with the results of the wet test. Do you have an aftermarket fuel controller? If you do I would say the rings washed out, and you should see about getting the settings re done. Did you happen to get a smell of your oil when you changed it? Smelling gas in the oil is almost always a sign of running too rich and being well on your way to new rings. If you don't have one then wow Harley motors suck!
