forks??
Old Dec 15, 2009 | 09:42 AM
trailey97's Avatar
trailey97
Cool forks??
has anybody cut some coils off thier forks to lower the front end down some??
Old Dec 15, 2009 | 11:08 AM
mreed's Avatar
mreed
I've done it several times.
I lowered this bike a little over 2" by cutting the coils.
And this Fat Boy the same way.
I've done a few metrics as well.
I have no problem at all doing it. I would suggest going with a heavier fork oil if you cut the coils.
Old Dec 15, 2009 | 01:03 PM
FandA M's Avatar
FandA M
How low do you want to go? If it's just an inch or so you can just slide your fork tubes up the trees a little..............might be easier and if you don't like it you can put'em back.
Old Dec 15, 2009 | 07:26 PM
mmzullo's Avatar
mmzullo
I agree with Fanda m on raising the forks in the tree. I did it on my sporty about 3/4 of an inch. It lowered the bike quite a bit. I have 4 inch longer forks in my bike. This bike was new to me and I just wanted it lowered. Road much differrent. I just today replaced my fork tube with stock lenght because 1 that had a bad seal. Haven't rode it yet. Too much road grime on the roads.
Old Dec 16, 2009 | 08:08 PM
trailey97's Avatar
trailey97
sweet well i was gonna do the lowering blocks in the rear from jp cycles. and my bike already seems to sit a lil low in the rear. not sure by how much.
i used to work at a coil spring machine shop so i was thinking about getting them to do it for me. good thing i left on good terms. haha
Old Dec 16, 2009 | 08:10 PM
trailey97's Avatar
trailey97
mreed.... what shocks are those on the rear of your sporty? i like how low that sits...
do you bottom out? i weigh about 170lbs so thats my biggest concern
Old Dec 16, 2009 | 08:49 PM
89heritagesoftail's Avatar
89heritagesoftail
yeah, i'm thinking i'm gonna just put in the gold valve emulators and heavier fork oil after i slide my forks up a bit more. right now i have it up about an Inch and 1/4, and haven't bottomed out but once, but that was a bad dip.
but i'd like to lower it like another half to 3/4's... i think the emulators and heavier fork oil should do it enough. right?
Old Dec 16, 2009 | 09:43 PM
mreed's Avatar
mreed
They are the stock shocks from my Nightster (1" shorter than stock) and the lower mount is relocated rearward 2" with some pieces I made.
I haven't ridden it though. It's a project bike & that was something I did to get it low but decided to hide a mono-shock in there. But, my wife's bike has the stock shocks & the lower mounts moved rearward 3". She doesn't bottom out on it & I've ridden it with my daughter on the back with no problems but we don't have alot of crappy roads here...
My wife's
I used Progressive fork springs with very short top spacers and stock rear shocks with the mount relocaters. Hers rides great. Much much better than stock.
Old Dec 17, 2009 | 07:06 AM
trailey97's Avatar
trailey97
i live just outside houston so not too many bad roads here either.
how much would ya charge to make me set 2" back? pm me it
Old Dec 17, 2009 | 08:21 AM
83XLX's Avatar
83XLX
Don't the forks get pretty spongy when you shorten the springs? You're taking all the preload off when you do that. I recently replaced my fork springs with Progressives, and while experimenting with preload spacers, ran with very little preload for a test - the thing wallowed all over the place when taking a curve.
