Kickstand question
Old Mar 5, 2010 | 08:10 PM
holt2010's Avatar
holt2010
Default Kickstand question
Hey guys so Im riding a sportster 883 with the shocks lowered all the way and the front lowered all the way, and the kickstand is a bitch to get down. I was thinking that it was too long whats your opinion? Also about an hour ago i was parked at the local Mcdonalds with one of my friends and we were sitting there talking and I go to start my bike and the kickstand is down all the way like it should be and everything is fine and I go to put my helmet on and my bike falls over on the right side. It bent my brake lever and tore up the right handlebar grip some but other than that shes fine, thank god. Any comments on that I just thought it was odd that my bike just randomly fell over on the right side.
Old Mar 5, 2010 | 09:23 PM
HOTLAP's Avatar
HOTLAP
Sounds like since you lowered it the stand is now holding the bike too upright, if you want to keep the bike at that height you will need to remove the stand and either carefully bend it using a vise and a snipe or have a good welder cut out a section and re-weld it together so it's shorter.
Old Mar 5, 2010 | 10:00 PM
holt2010's Avatar
holt2010
Thanks HOTLAP ill have to raise the front back up then, im beating myself up cause my bike fell over, ive only had it about a month.
Old Mar 5, 2010 | 10:05 PM
Tao3535's Avatar
Tao3535
Everybody drops a bike sooner or later, usually right after you get one. You had an excuse and it's something you can fix so I wouldn't feel too bad.
Old Mar 5, 2010 | 10:08 PM
holt2010's Avatar
holt2010
so raising the front back up will fix my problem?
Old Mar 5, 2010 | 10:13 PM
HOTLAP's Avatar
HOTLAP
The more you lower the bike the more it will stand more uprite on the stand, it sounds like you are already at the point that a small breeze will knock it over so you need to raise the bike or shorten the stand to get some lean to it.
Being very careful where you park also helps, try to find a pot hole or low spot to put the stand so it leans over more.
Old Mar 6, 2010 | 05:35 AM
tiger_rider's Avatar
tiger_rider
Try searching this site for discussions on kickstands or jiffy stands. I remember somewhere someone had a similar problem and they thought that the stands for the nightster were shorter.
Old Mar 6, 2010 | 06:20 AM
back again's Avatar
back again
Get a kickstand for a Low model.I had the same problem with my bike after lowering.I'm running -2" front and 10.5 shocks with a long swingarm.Found the new stand on e-bay for 30.00.
Old Mar 9, 2010 | 11:03 AM
WVHogRider's Avatar
WVHogRider
+1. That's what I had to do when I went from ~12.75 stock rear shocks to the 10" short shocks, but I didn't touch the front.
Old Mar 9, 2010 | 05:39 PM
HarleyScuba's Avatar
HarleyScuba
I put a Nightster jiffy stand on the OL's '05 1200C after lowering the rear. Huge difference.
Robert Strohl
Nov 16, 2014 07:20 AM
medic2931
Apr 20, 2009 03:50 PM
tdragano
Sep 13, 2008 09:43 AM
Fatbernie
Oct 29, 2007 09:07 AM
TRITON
Jul 15, 2006 08:40 PM
