starter engaging when ignition is turned on
Old Aug 5, 2006 | 07:30 AM
shanetenn's Avatar
shanetenn
Stage III
Default starter engaging when ignition is turned on
please help.
just changed the oil and washed up the bike. took it out for a ride and the starter engaged while i was riding.
can anyone tell me what would cause the started to engage when i turn the ignition on, but i do not push start button.
thanks
Old Aug 5, 2006 | 09:26 AM
Dan B's Avatar
Dan B
Default RE: starter engaging when ignition is turned on
Pull out the starter relay.
If the starter still engages when turning ignition on, the problem is probably in the starter.
If not, problem is probably starter realy or start button.
Since you just washed the bike I guess something got to much water on it, try to drie starter area
Old Aug 5, 2006 | 09:34 AM
BigTinVA's Avatar
BigTinVA
If you use a leaf blower to dry off your bike make sure to blow out the handlebar switch housings real well. I think you may have let water sit in there. I bet you will be fine after the bike dries out real well. The last time I washed my Softail, my turn signals were acting real screwey until the switch housings dried out.
Old Aug 5, 2006 | 11:00 AM
brohrs's Avatar
brohrs
You got water in the switch,just let it dry out and back to normal. You have to cover those switches with plastic when you wash it to be safe.
jim70
Electrical/Lighting/Alarm
Nov 16, 2015 05:21 PM
Aussiemadness
Jan 11, 2015 10:54 AM
Wildman1967Chevelle
Jun 23, 2011 03:19 PM
Nostalgic07
Jun 19, 2011 09:43 PM
zacjac
May 5, 2007 10:50 AM
