No simple way ?
Old Aug 6, 2006 | 08:56 PM
cajun883custom's Avatar
cajun883custom
Default No simple way ?
I suppose that there is no simple way to remove the baffles out of the Screamin' Eagle II's?
I bought the Big city thunder ones, but cant seem to remove, Like somebody told me, i may
have to remove the muffler, which i didnt want to do.
Any suggestions?
Old Aug 6, 2006 | 09:45 PM
MidWest XL's Avatar
MidWest XL
Default RE: No simple way ?
I'll be watching this one. In particular, how the sound with the TH baffles differs from the SEs.
As far as removing the mufflers, I'd do that anyway to minimize scratching or scuffing up your mufflers. Plus having them on a bench when you swap them out will no doubt minimize the baffle removal and installation effort.
Old Aug 7, 2006 | 01:59 AM
TJ461vs's Avatar
TJ461vs
Cajun
Find a metal rod of some type and bend it into a hook. Insert that into your pipes and give it a good tug. If they don't pull out start the bike, let the pipes warm up turn the bike off and the old baffles will slide right out with no problem. When I installed my big city thunder baffles I used a metal file handle that was bent at a 45 degree angle and with the pipes hot the old baffles came right out with nearly no effort at all. Just be careful not to burn yourself. Let me know how it works.
Titan56
Jul 23, 2012 01:24 PM
Steel Steed
May 5, 2012 04:39 PM
beerpong75
Mar 27, 2008 06:04 AM
tcartwr332
Sep 14, 2007 08:51 PM
kaduku
Apr 8, 2006 03:04 PM
