Lowering a 1200 Low??
Old Apr 22, 2010 | 02:56 AM
sbcvulcan's Avatar
sbcvulcan
Default Lowering a 1200 Low??
Although not necessary for myself but could consider, I have come across people who indicate they have lowered their Lows via shocks. Is this an ok modification or is there an impact to the ride? is there a best way to lower this bike and is that an expensive process?
Old Apr 22, 2010 | 04:02 AM
XLCR4GM's Avatar
XLCR4GM
To lower the Sportster Low via shocks is easy to do. Just change out the stock shocks to a shock with a shorter length. The problem comes at the loss of ground clearance/cornering ability and the loss of some comfort due to the reduced shock travel from the shorter shocks when going over bumps. The kickstand might have to be altered as well if the bike is lowered too much and you can only lower it to a given point before the rear tire comes into contact with the rear fender and you don’t want that to happen.
Is there a best way to lower this bike and is that an expensive process?
Again, using a shorter shock would probably be your best bet and easiest way to lower the bike and the expense would be whatever the cost that you would want to spend on a shorter pair of rear shocks.
Old Apr 28, 2010 | 08:58 PM
peggy's Avatar
peggy
lowering blocks, less than 100 bucks and lowered 1-1.5 inches,im flat footed in sneakers now ,love it
Old Apr 28, 2010 | 09:08 PM
SeeMeDo's Avatar
SeeMeDo
Man they're pretty low out of the box maybe try a different seat one of those forward low ones don't remember the name but hey it's keg time.
atrain68
Mar 15, 2013 04:55 PM
Ben E
Oct 31, 2012 06:44 AM
Fhatboy
Mar 26, 2012 10:43 AM
Warrior Redleg
Sep 21, 2011 04:45 PM
asheborogn
Jul 11, 2010 04:39 PM
