next question on 592 code
Old Apr 29, 2010 | 11:02 PM
Jerseyrider's Avatar
Jerseyrider
Question next question on 592 code
2007 xl883c pc3 and v& h short shots
still having low battery voltage code,
c know how to reset just itching to ride,
cked vreg voltage 16vdc comming off regulator while running, is this voltage good??
cked continuity from v reg to battery (pos connection and was good onee side to ps one to ground? ???
Old Apr 30, 2010 | 01:44 AM
Aires59's Avatar
Aires59
Can't help with resetting the fault code but 16v is a bit high, for a 12v system you would expect about 14.5v from the regulator.
Old Apr 30, 2010 | 05:34 AM
cHarley's Avatar
cHarley
16 volts is too high. Also, I'm not sure what a 592 code is. Trouble codes on your bike should consist of a Letter followed by 4 digits, such as;
B0563 - Battery Voltage High TSM/TSSM
I don't find any codes that consist of - x0592
Old May 1, 2010 | 08:01 PM
Jerseyrider
Default ooops
sorry all beind way to tired code is B0562 low battery voltage
kevjo
Sep 10, 2018 06:51 PM
DarkManC
Jul 10, 2009 07:24 PM
pococj
Jul 8, 2009 05:33 PM
ladodgerdog
Sep 22, 2008 10:56 PM
WRAITH
Apr 24, 2008 06:59 AM
