Need Help with Code P0562
Old Sep 22, 2008 | 08:42 PM
ladodgerdog's Avatar
ladodgerdog
Default Need Help with Code P0562
I got this code yesterday on my way home after riding all day. P0562 - Battery Voltage Low EFI, what does this mean?
Old Sep 22, 2008 | 10:28 PM
luckyB's Avatar
luckyB
From the 2008 Dyna Model Electrical Diagnostics Manual:
Notes - When either Diagnostic Trouble Code (DTC) P0562 or P0563 is set, the battery icon in the speedometer will illuminate. 1) DTC P0562 is displayed when battery voltage is less than 12.2 volts at idle and voltage does not increase when engine speed is greater than 2000 RPM. 2) TSSM/HFSM problems may also set a DTC P0562 or P0563.
Diagnostic Tips - 1) Low voltage generally indicates a loose wire, corroded connections, battery and/or a charging system problem. 2) A high voltage condition may be caused by a faulty voltage regulator.
Hope this helps...
Old Sep 22, 2008 | 10:46 PM
ladodgerdog
Yes it does. Thanks LB!
Old Sep 22, 2008 | 10:56 PM
luckyB's Avatar
luckyB
No problem.
Stevie Porch
Electrical/Lighting/Alarm
17
Jun 7, 2018 04:34 PM
lv2ride56
Oct 20, 2013 04:37 PM
Jerseyrider
May 1, 2010 08:01 PM
DarkManC
Jul 10, 2009 07:24 PM
pococj
Jul 8, 2009 05:33 PM
