Metal shavings in trans fluid??
Old May 14, 2010 | 08:21 PM
OldFenderGuy's Avatar
OldFenderGuy
On the Sportsters you get a 'double wammie', as the fluid is shared by both the clutch plates and the transmission gears.
On the big twins you will also get the fine 'dust' on the magnetic drain plug for the primary (which doesn't share oil with the transmission).
Fine 'dust' on the magnetic plugs (either tranny or primary) is normal.
But if you start getting hard particals such as chunks or shavings you have a problem.
JackKnife5
General Topics/Tech Tips
Jul 10, 2018 07:28 PM
UT-rckr
Dec 17, 2012 10:29 PM
Low_Wider
Sep 11, 2012 05:25 PM
met.75
May 2, 2009 08:30 AM
met.75
Apr 29, 2009 05:09 AM
