Ignition/Coil Relocation Q
Old Jun 3, 2010 | 09:21 AM
WDHGS's Avatar
WDHGS
Default Ignition/Coil Relocation Q
For those of you who have done this project and had it installed for a while on your bike, have you experienced any problems since doing so? Any problems with engine heat? This project obviously helps to clean up the front end a little, but does it provide any other functionality? Are there any particular kits available that work best?
Old Jun 3, 2010 | 10:09 AM
joebotics's Avatar
joebotics
I didn't use a kit... I did this:
https://www.hdforums.com/forum/sport...n-my-take.html
after 8k no issues with heat or the assembly breaking ...
Old Jun 3, 2010 | 06:54 PM
Cyclops's Avatar
Cyclops
I kept my ignition in the stock location because I find it to be functional and out of the way. My coil is relocated to the side and mounted to the cylinders in a similar manner to a traditional horn mount. No issues with heat. I didn't use a kit as it was very easy to fabricate.
Old Jun 3, 2010 | 09:43 PM
capitalist_slave's Avatar
capitalist_slave
No problems, just compliments.
Ditto, i don't get moving the ignition away from the fork-lock that uses the same key.
Old Jun 3, 2010 | 10:18 PM
WDHGS's Avatar
WDHGS
Hey JoeB.-thanks for the link, great write-up and look! I might give this a shot tomorrow evening as it's supposed to rain here...and rain for the entire weekend as well....and the next two days after that...I guess I can really take my time.
Thanks for the info guys--appreciate your thoughts.
twhill3
Jan 30, 2015 08:08 PM
astark
EVO
Aug 2, 2013 12:29 AM
DougYITBOS
Oct 15, 2012 10:52 PM
jizquie560@aol.com
Aug 12, 2009 02:19 PM
swords
Oct 10, 2007 05:54 PM
