Please everyone read this..i need help!
Old Jun 9, 2010 | 06:20 PM
junk_sportster's Avatar
junk_sportster
Stage II
Default Please everyone read this..i need help!
I have a 2004 XL1200c with 6,340 miles with a screamin eagle hi flow air cleaner. The screw backed out of the air cleaner assembly and was sucked into my carburetor, leading to a total engine failure. it ruined my front cylinder head, cylinder, desinigrated the piston, bent a valve and twisted a connecting rod. HAS ANYONE ELSE HAD THIS ISSUE OR KNOW OF ANYONE THAT HAS HAD THIS ISSUE? HD wants nothing to do with me now. After I had the dealer install their performance parts, had all the service work done at a dealer, they dont want to offer any assistance to help me! PLEASE, IF ANYONE ELSE OUT THERE HAS HAD THIS PROBLEM OR KNOW OF ANYONE PLEASE LET ME KNOW!!
Old Jun 9, 2010 | 06:37 PM
Thatzmister2u's Avatar
Thatzmister2u
It is not that uncommon of an issue. If the dealer did the install on the A/C intake they should fix it. Be persistent. Talk to the manager. I am guessing they did not apply loctite to the screw.
Old Jun 9, 2010 | 07:04 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
If the damage was directly caused by a mistake in their work, then it most certainly is covered.
Old Jun 9, 2010 | 07:10 PM
WDHGS's Avatar
WDHGS
Their mistake, their repair bill, don't let them off the hook.
Old Jun 9, 2010 | 08:03 PM
cHarley's Avatar
cHarley
+1 - It happened because the dealer failed to use Loctite on the screws, as the installation instructions call for.
Old Jun 9, 2010 | 08:32 PM
xFreebirdx's Avatar
xFreebirdx
+2 I'd search the entire forum. You'll find plenty about it.
Last one in it is the one who focked it up.
Old Jun 9, 2010 | 08:45 PM
twistr's Avatar
twistr
The "dealer" that did the install should be responsible for the damage, but NOT the MOCO. Don't let this dealer off the hook!!
Old Jun 9, 2010 | 08:48 PM
Badmonkey80's Avatar
Badmonkey80
Plus the bolts should have been checked at the last service, if they installed the air cleaner, and did the service.. Double Fail.
Old Jun 9, 2010 | 08:51 PM
KCFLHRC's Avatar
KCFLHRC
What screw/bolt are you talking about????????? I definitely want to check mine.
Old Jun 10, 2010 | 07:47 AM
XL50#674's Avatar
XL50#674
I have heard of this issue if you do not use loktite. I used some on my when I installed the SE ac, but read about this issue a few days later and wnt home and put more on LOL!
Matthiatron
General Topics/Tech Tips
Aug 5, 2014 12:33 AM
junk_sportster
Jun 10, 2010 01:52 PM
bubba 40
Shovelhead
Feb 15, 2010 06:04 PM
harveydonaldson
Mar 19, 2009 03:36 PM
08HD
Apr 14, 2008 10:05 AM
