Stupid question 049
Old Jul 24, 2010 | 01:01 PM
DavidStiebel's Avatar
DavidStiebel
Talking Stupid question 049
What is the little sproket under the trottle handle? Tension for the cables, throttle adjust? Electronic headlight adjust?
Man I feel dumb asking this but I have not recieved the manual I bought.
Old Jul 24, 2010 | 01:36 PM
CheezHead's Avatar
CheezHead
It's a throttle lock so you can rest you hand when it gets tired or falls a sleep. Sort of like a cruise control.
Old Jul 24, 2010 | 01:49 PM
DavidStiebel
thanks
Old Jul 24, 2010 | 06:37 PM
scooter1128's Avatar
scooter1128
you can also use it to adjust the tension on your throttle. if its backed out (loose) any little bump may cause you to blip the throttle. snug it a bit, little more effort but not to sensative. and like what was posted...cruisin down the road, you can snug it enough to take your hand from it.
Old Jul 24, 2010 | 08:12 PM
asm481's Avatar
asm481
I wouldn't suggest riding with it tightened at all. Maybe a few resting minutes running down the empty superslab but not around town. There was a post in here where a rider inadvertently tightened his up and rear ended a cage. I think he was a bit upset and didn't think it should be there.
Old Jul 24, 2010 | 08:14 PM
fattboy1967's Avatar
fattboy1967
Old Jul 24, 2010 | 08:27 PM
scooter1128
i wasnt endorsing locking it down at speed, as asm481 stated in the city or with heavy traffic present. but if on an open road to give your hand a rest you can or another example, this past winter (pretty cold), i did this long enough to rest my right gloved hand on the rear jug to warm it up. but as stated, it is not a cruise and will not back off by hitting your brakes...you will manually have to back the star (loosen) or if something happens you just simply rotate the throttle back by hand.
ppilotmike
2018+ Softail Models
Sep 26, 2019 12:18 PM
harley0101
Dec 18, 2014 09:53 PM
1NewHDGuy
Jun 16, 2014 06:46 PM
PhattyBob12
Jul 14, 2012 10:07 AM
plane
Aug 12, 2008 10:08 AM
