Mini Floorboards with forward controls?
Old Sep 10, 2010 | 06:24 PM
offduty135's Avatar
offduty135
Question Mini Floorboards with forward controls?
Just bought this pair of the chrome works universal mini floorboards:
http://www.jpcycles.com/product/5500000
They offer two positions - 0 degree or 15 degrees. I have an '06 1200 XL and it appears neither angle will work properly. They cycle's peg mounts are already at an angle that doesn't work with the 0 or 15 degree choices... The boards are either slanted forward or nearly upright...
Anyone had success? Do I need a different model?
Thanks!
Old Sep 11, 2010 | 06:12 AM
trmac's Avatar
trmac
Big Kahuna HDF Member
What if you put them on the opposite sides?
The fitment specs don't list Custom Sporty so they may only work for mid controls.
Old Sep 11, 2010 | 06:28 AM
Zimbob's Avatar
Zimbob
I know on the pre '04 Sportsters, the part that the peg mounts into can be rotated to any angle you need, aren't the '04+ Sportsters like that? Did I misread something here?
Old Sep 11, 2010 | 06:32 AM
WVleo's Avatar
WVleo
Default Floor boards
Hi, Not really sure about fitment of the floorboards You posted, but I use this set up with My 06 1200C . The stirrup adds support to My heel the same way floorboards do. They are Kury pegs. Just a thought . WVleo
Old Sep 11, 2010 | 07:34 AM
offduty135's Avatar
offduty135
Thanks for all the quick replies. Zimbob, I'll have to check into the peg rotation. That would solve it. It didn't appear to me to rotate, but there is a screw securing the the peg mount, so maybe it does rotate. Anyone else know?
I was thinking about the pegs with a stirrup as an alternative. I may also just break down and buy the HD mini floorboard kit, which offers full rotation at 10 degree intervals. Pricey ($109) and they are very small boards.
Trmac - I did try to switch sides, but it didn't help. You either end up with a 30 degree forward slant or about 60 degree up/down.
Thanks again.
Old Sep 13, 2010 | 03:43 AM
trmac's Avatar
trmac
Didn't know if the side switch would work or not - guess not.
I put the HD mini boards on the passenger mounts to keep shoes off the muffler - so far they're doing the job. The full rotation is nice. They are pricy but you should be able to order from one of the places that give discounts.
Old Sep 13, 2010 | 07:56 AM
dixie FLSTS's Avatar
dixie FLSTS
I have used a set of the Kury mini wings which are small triangle shaped boards about the sizre of your hand.
They came made to mount on the rear footpeg stems so the indentation for the set screw was in the wrong place to use on the foward controld so I just took them apart and added another indentation with a 1/4" drill bit and they worked great.
Old Sep 13, 2010 | 04:13 PM
HarleyScuba's Avatar
HarleyScuba
Here's a pic of the foot peg mounting shaft, shift/brake pedals (which pivot on the shaft) and the shaft through-bolts after being powder coated. You can see where a bolt threads into the peg mount shaft. That bolt goes through the frame mount for the shaft. The shaft is fixed.
Maybe someone makes a swivel peg extender. Can't help ya there. Extensions may severly limit cornering clearence.
I use a set of stirrups from Harley on my Softail and love 'em.
Old Sep 13, 2010 | 09:34 PM
DaytonaSportster's Avatar
DaytonaSportster
I love my Duallys on my custom!!
dfarley91
May 2, 2017 09:16 AM
imjuslazy
Feb 9, 2017 10:46 PM
Sherry FXDC
Jul 17, 2012 04:30 AM
testiclease
Mar 16, 2011 09:46 AM
mbwannabe1
Jan 10, 2009 10:45 AM
