wider rear tire for forty-eight? possible?
Old Sep 16, 2010 | 03:29 PM
bamboo168's Avatar
bamboo168
Default wider rear tire for forty-eight? possible?
Looking to get a new 2011 Sportster Forty eight, but wants to know if I can put a wider tire on the back? what is the largest size I can upgrade without suffering handling? 180? 200?
thank you
Old Sep 17, 2010 | 01:04 AM
chevy94ss's Avatar
chevy94ss
Maybe a 160 from certain manufacturers but that's probably the widest without a wide tire kit($$$). There's really not a lot of room back there.
Old Sep 17, 2010 | 06:00 AM
Guest
Guest
Posts: n/a
A 150 is the widest you can go without handling suffering. You can probably stuff a slightly wider tire under there, but why would you want to? That would totally change the entire balance of the bike.
Old Sep 17, 2010 | 06:27 AM
xFreebirdx's Avatar
xFreebirdx
The rear already has a 150 on it..........
Old Sep 17, 2010 | 06:31 AM
Guest
Guest
Posts: n/a
I'm aware of that. That's the point I was making, actually.
Old Sep 17, 2010 | 07:15 AM
mreed's Avatar
mreed
If you go with a chain you'll be able to squeeze a little more in there. It's your rear frame width that will be what holds you back.
I don't agree with the wider tire = worse handling. I have one with a skinny 21 and 130 rear that doesn't handle as well as my Nightster...just as my bike with a 180 rear and 130 front blows them both away in regards to handling.
Old Sep 17, 2010 | 08:26 AM
Guest
Guest
Posts: n/a
It isn't that a wider rear than front automatically handles worse. The point is that the frame geometry and tire width are engineered to work together to achieve a certain handling balance, and changing that to make the rear wider than the front negatively impacts handling. It isn't always a huge impact, but it is still there. Whether that impact bothers you depends on how you ride, and your tolerance for poor handling. Of course, anyone who has forward controls automatically has a huge tolerance for poor handling, and so may not feel that a wider rear tire is a problem.
Old Sep 17, 2010 | 08:31 AM
xFreebirdx's Avatar
xFreebirdx
The wider tires in the front and rear actually improve handling.
Old Sep 17, 2010 | 08:32 AM
xFreebirdx's Avatar
xFreebirdx
+1....I only have a 130 / 100 and it sticks like glue,
Old Sep 17, 2010 | 08:35 AM
xFreebirdx's Avatar
xFreebirdx
That only comes into play when you move up to the super wides that tend to be flatter in the middle.
