I just made a speedometer relocation bracket.
Old Mar 15, 2012 | 11:42 AM
  #41
nc883's Avatar
nc883
My bracket looked like this:
http://www.ebay.com/itm/Harley-David...#ht_500wt_1199
I cut it just above the indicator section, and filed it so it was completely smooth/round. Put the leftover indicator section back on the upper clamp. Used the Autometer clamp you've seen, removed the rubber section, and clamped my original (now perfectly round) speedo pod inside the clamp. Picked up a 6" bolt from the hardware store, used a 1" long "sleeve" I had laying around as a standoff to push the mount out from the tank, enlarged a hole in the autometer mount bracket, and put a nut on it. I did have to extend my speedometer wiring roughly 8 inches as well, but has been working just fine the past few weeks.
Old Mar 15, 2012 | 12:30 PM
  #42
djw88's Avatar
djw88
Looks awesome a lot cleaner looking than the one from summit custom made is always better then it is truly making it your own not just buying and slapping parts on.
Old Feb 8, 2013 | 04:13 PM
  #43
chaddallas's Avatar
chaddallas
how did you extend your speedo wiring?
Old Jun 3, 2016 | 08:43 PM
  #44
le loup's Avatar
le loup
Stage III
Well done mate ,i will order a powder coated one if you can make it .
just let me know
Old Jun 3, 2016 | 08:53 PM
  #45
Delnorin's Avatar
Delnorin
Here is the DKCustomProducts.com relocation kit.
http://dkcustomproducts.com/Sportste...-SPT-SPILR.htm
reesestewww
May 22, 2020 03:25 PM
JasonDeal
Dec 3, 2014 06:19 AM
ryan9977
May 19, 2012 05:30 PM
Blueman86
Jan 31, 2012 07:00 PM
cricket1116
Sep 24, 2009 11:06 PM
